Which bilge pump switch?
- Been thanked: 654 times
Re: Which bilge pump switch?
- Been thanked: 1111 times
You panel switch is a "on-auto" switch. It is really just an "on-off" for the "continuous" function of the bilge pump. The diagram posted is likely not going to be correct for your boat because that would mean that both the "continuous" and "auto" are fed from the same fuse which is unlikely, as the "continuous" would be connected after the battery switch and the "auto" is before the battery switch.
On the switch, the ground is for the light. the power comes into one of the other tabs and the pump connects to the other, so when the switch is "on" those two tabs are connected together. The positive side of the light is also connected to one of those tabs and that should be the same side that the pump is on, so that when the pump has power, so does the light.
- CptBacardi
- Vessel Info: 1989 Carver 38 Santego (not an aft cabin)
- Has thanked: 3 times
- CptBacardi
- Has thanked: 602 times
- Been thanked: 1310 times
I still believe that one of those brown wires is connected to somewhere else, but the switch change will verify that.
- CptBacardi
