mercruiser 4.7 manifold and riser replacement
cpoint
Has thanked: 208 times
Been thanked: 32 times
Postby cpoint » November 21st, 2018, 11:44 pm
Here we are another season is over, when it starts, I am already lined up with work :-(
Basically I was told I need to replace my mercruiser 4.7 manifold and riser on both engines, as I have been apparently very lucky that my 2000 carvers original manifold and riser have not given up yet, but they are ticking bomb at this point. I did research and looks like that I have been lucky, as these things needs to be replaced every 5-6 years I read everywhere and been told by everybody. So there goes more green stuff :captain: Any input, suggestions, comments appreciated as always. Luckily, so far nothing happened, as in water leaking into engines.
Re: mercruiser 4.7 manifold and riser replacement
Postby tomschauer » November 22nd, 2018, 1:01 am
I assume have 5.7's not 4.7's as listed. Are they raw water cooled or fresh water cooled? If they are fresh water cooled you most likely only need to replace the risers.
buster53
Vessel Info: 2001, Carver 356
Has thanked: 10 times
Been thanked: 285 times
Postby buster53 » November 22nd, 2018, 4:07 am
tomschauer wrote:Source of the post I assume have 5.7's not 4.7's as listed. Are they raw water cooled or fresh water cooled? If they are fresh water cooled you most likely only need to replace the risers.
Tomschauer is correct. If you have a full fresh water cooled engine where the manifolds are included in the closed cooling system, as far as rust and corrosion goes, they should last as long as the engine block. Risers/elbows are a different story. Depending on how salty the water is you boat in, they could only last maybe 4-8 years.
Been thanked: 248 times
Postby mjk1040 » November 22nd, 2018, 6:56 am
I think he meant 7.4L engines if it's a Carver 356! Riser replacement time frame would depend on what type of water the boat has been in. If you are in salt water, then yes the time frames you were given is about right. I'm in fresh water non salt and our are original from 1998 on our crusader's!
darrenlife
Vessel Info: 2002 Carver 410 Sport Sedan
Been thanked: 36 times
Postby darrenlife » November 22nd, 2018, 9:03 am
Either way, use a generous amount of liquid wrench and let that soak in. You should be able to see the shank of the long boat on the side of the riser, use this to sight if the bolt is attempting to turn as you apply torque to your socket handle. Go slow, you won’t want to deal with a broken bolt.
buster53
Postby buster53 » November 22nd, 2018, 9:45 am
darrenlife wrote:Source of the post Either way, use a generous amount of liquid wrench and let that soak in. You should be able to see the shank of the long boat on the side of the riser, use this to sight if the bolt is attempting to turn as you apply torque to your socket handle. Go slow, you won’t want to deal with a broken bolt.
Liquid Wrench or PB Blaster...don't just use it, use it a couple of times and even run the engines a few minutes between soaks over a couple of days. The vibrations of the engines running will help the penetrating oil soak down the threads of your bolts.
Agree that the OP meant to say 7.4's. A 356 needs big blocks, not 5.7's.
Postby tomschauer » November 22nd, 2018, 12:04 pm
Most likely 7.4's, but the 355's and 356's were available with 5.7' mags.
cpoint
Postby cpoint » November 22nd, 2018, 2:31 pm
No, not fresh water unfortunately.
cpoint
Postby cpoint » November 22nd, 2018, 2:33 pm
Sory, typo 7.4 MPI. Also it is in brackish water.
Postby tomschauer » November 22nd, 2018, 11:17 pm
Then it most likely time to change before they leak water into the cylinders.
Users browsing this forum: Google Adsense [Bot] and 26 guests
