2006 Carver 36MY TV cable question
- Cliffm
"the Condo"
- Has thanked: 260 times
- Been thanked: 19 times
Both TV's each have 1byone flat panel TV Antenna's attached, with coax cable undone. There is a "cable box" connection under the swim step stairs. There is also an Omni direction TV antenna on the arch, same area as GPS/Radar dome, installed by first owner.
We would like to be able to use a dockside cable TV hookup, but I'm wondering about this TV antenna on the arch? is it a factory option?
Ideally we'd like a splitter to select cable or antenna, but realize that it must be upstream of a splitter for both TV's.
My question is the factory location of the splitter to both TV's from the cable connection under the stairs?
my other question is access to the "inside" of the salon TV cubby, as it appears the gray cloth behind the TV is glued on?
do most folks undue the DC panel to get better access into this cubby area? such as accessing the rear of CMD4 stereo?
as always, and insight is appreciated!
- Has thanked: 313 times
- Been thanked: 581 times
Re: 2006 Carver 36MY TV cable question
- RGrew176
- Vessel Info: 2022 Stingray 182 SC
- Has thanked: 72 times
- Been thanked: 462 times
- RGrew176
tomschauer wrote:Source of the post Rick, just an FYI, there is no digital or analog antenna. They are all the same. TV stations no longer broadcast in analog, so if you don't have an digital (hd) tv tuner it will cannot decode the digital signals.
That's why I have the converter box. It's hooked to the cable that comes from the antenna then connected to the TV. It will not work by itself. I tried it first then connected the converter box to the antenna cable to make it work. I pick up about 25 or so channels where I am located.
- Been thanked: 586 times
- Has thanked: 253 times
- Been thanked: 1093 times
- Cliffm
"the Condo"
tomschauer wrote:Source of the post My boat is several years older than yours, but the cable / antenna switch is behind the tv in the aft cabin. Yours may be there also.
Good to know, I'll start looking there, thanks
- Cliffm
"the Condo"
Midnightsun wrote:Source of the post Mine is a 2007 so I would assume similarly wired. The switch under the stairs allow for A/B selection. Arch mounted antenna or dockside cable. Maybe you already have it? Under the protective cover where your shore power is you may have one marked telephone/cable.
Thanks, I'll check for this switch and ohm out the connection next to the shore power connection, so I know which is which.
Thanks for the insight, as always, it is much appreciated!
Users browsing this forum: No registered users and 37 guests
