Crusader won't break 2100 RPM's
Jab
Topic author - Scurvy Dog
- Vessel Info: 1978 Santa Cruz 2866
Moosehead Lake, Maine - Been thanked: 1 time
The good news- I don't need it to. We use the boat mostly as a floating lake camp. In the summer I work from it. At 1800 RPM's it runs 7.5 kts, which is fine for our cruising needs. When we want to go fast, we use a different boat.
The engine starts easily and runs fine. No stalling or misfires. No steam or smoke. No overheating. No 'milky' oil. We use 91 octane ethanol-free fuel.
I will have our marina mechanic check her out. I'd like to be able to ask some intelligent questions (or at least understand half of what he tells me).
My reading makes me guess a fuel restriction problem? Planning to check fuel lines, anti-siphon valves, and mechanical fuel pump, water separator and fuel filters, and clean carb.
What other questions should I be asking?
Thanks... JB
- Has thanked: 64 times
- Been thanked: 481 times
Re: Crusader won't break 2100 RPM's
If the fuel filters (in carb and external) are fine, my next two guesses would be a partially blocked/stuck anti-siphon valve or bugs have built nests in your fuel tank vent fittings and are partially blocking the screen.
Let us know what you find.
- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
Is that in gear, or in neutral?
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
Jab
If I get 3600 RPM in neutral, and only 2100 in gear, what else does that add to the list?
- Lyndon670
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Jab
Just curious- would under-propped affect RPMs, or speed at any given RPMs, or both?
- Lyndon670
You can destroy a motor very quickly if you have a prop under/over what is recommended.
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Jab
Under way I get to 2000 RPM with about 1/3 throttle (meaning 1/3 travel on the throttle lever)), and only about 2200 with WOT.
- Lyndon670
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
