Starboard engine still running hot
- Helmsman
- Has thanked: 73 times
- Been thanked: 42 times
Another post shows the steps I have taken. viewtopic.php?f=8&t=3764
1) when I winterized the 5 gallon jug I was pulling the antifreeze through took a lot longer to pull through the engine than the port engine did,
2) I treated the engine with Ridlyme and it improved the flow. Still slower than the port engine but thought it would buy me some time.
3) the boat is 13 years old. I went ahead and bought replacement heat exchangers, oil coolers, transmission coolers, and thermostats. I also am going to buy new hoses. Everything I read says that they are probably past their service life.
Questions are:
Are the temp gun readings out of line with “normal”?
Any recommendation on brand of hoses to use? Some will be bought formed, along with about 24 feet of 1” hose for some straight runs. I will probably use wired hose.
Any gotchas involving the heat exchanger to watch out for?
Should I replace the risers and manifolds? (All fresh water use)
If I replace the risers and manifolds, should I buy new nuts and bolts? What is the best stuff to coat bolts with prior to putting the nut on them.
Should all the clamps be replaced or just re-use the old?
Any other thoughts, advice, or suggestions?
Thanks in advance.
- Been thanked: 490 times
Re: Starboard engine still running hot
Timing ok?
Fuel delivery ok?
- Helmsman
Timing is good. Had a problem with fuel two years ago. That was water in the fuel filter. Changed out and fixed it. Remember that the engine isn’t pulling water through the system as quickly as the port engine.
I pulled one hose at a time prior to the Ridlyme treatment. The water was constricted going to the exhaust manifold out of the heat exchanger indicating an issue with it. The problem is that the exhaust hoses are tight against the HE sides so I will have to pull to look inside anyway.
- mjk1040
- Been thanked: 248 times
- Has thanked: 602 times
- Been thanked: 1310 times
Based on this you may have found the problem, remove that thing and have it flushed and pressure tested.
To me the temps you got with the Ir gun did not seem outrageous, you will never get both exactly the same.....to be reasonably accurate with the gun you have to shoot the same spot on each and have the gun close to the spot you want to check.
keep us posted.
- Helmsman
I have ordered new hoses for both freshwater and raw water cooling systems. The pre-formed hoses from Marine Parts Source came in without wire in them, have the Crusader part number on them, but do not appear to be J2006r2 compliant. the bulk hose is Flex Shield 250 J2006R2 compliant and does have the wire in it. For those who have replaced hoses, do you just order using the part numbers and get the non-wired hose, or do you "make your own" with the wired version?
Second question. It appears that Dex Cool is the antifreeze recommended by Crusader in the manual (pink in color which is what appears to be in the engine now). The top off stuff that has been with the boat since I bought it three years ago is Prestone 50/50 Pre-diluted Antifreeze. I plan to use DexCool but have read about issues with seals and gaskets. My Crusaders are 2006 engines. The Dexcool is what you are supposed to use in GM engines. What type of AF do you use and why?
- Helmsman
A couple of things I learned. Getting the oil cooler out and replaced was a 12 hour affair for me. Tight and up under the engine made it difficult to get the leverage necessary to break the oil hoses attached to the 90 degree fittings loose. I had to order two new 90 degree fittings because the old ones were frozen on. After completing the hoses and the oil cooler, I will have to wait until after Memorial Day to change out the Transmission cooler and the HE.
Here is the Transmission cooler. I can’t tell much without the other hose removed and ran out of time to try to do that. Anyhow, some progress, but slow going.
- mjk1040
Users browsing this forum: Google Adsense [Bot] and 27 guests
