Carver Mariner 350 serpentine belt tensioner
- Blake
- Vessel Info: 2002 Carver 350
- Has thanked: 6 times
I had my alternator rebuilt over the winter. On splash day had a chirp from port engine, same as alternator that was rebuilt.
2002 Carver 350 with 6.2 L.
Looking at it, it looks like the belt tensioner pulley is not aligned with the other pulleys and is starting to chew the belt.
I didn’t touch any brackets but somehow the tensioner pulley is now angled. I only see two attachment bolts and both are tight. Has anyone experienced this?
Almost looks like I need a spacer on top bracket bolt but again I didn’t take anything off.
I’m attaching photo of the pulley and added yellow lines to show how the belt should be running.
The photo with arrow shows how the bracket seems to be out of alignment.
Thanks in advance.
UPDATED photo showing pulley and how it’s lined up.
- Been thanked: 1111 times
Re: Carver Mariner 350 serpentine belt tensioner
- Blake
It looks like pulley bracket needs a spacer?
It seems like the inboard side of pulley needs to be shimmed away from engine.
I’ll try moving pulley from full released to full tension.
- Has thanked: 602 times
- Been thanked: 1310 times
My guess..... the pulley is not seated just right., look behind it there is a ridged slide, if you have loosened it off too much it can get crooked....If that is not it, then no big deal to put a washer in the bracket to get it straight if you have to.
- Blake
I’ll compare to starboard engine, the pulley spins freely and no slop in it. So maybe bracket?
- Blake
It’s hard to see in photo but the tensioner pulley is definitely not in alignment.
There like a 1/16th to an 1/8th gap between straightedge right side on the tensioner.
You could also consider swapping the tensioner pully on both engines and see what each looks like. That would also give you the ability to compare them side-by-side which may reveal more differences. They should come off pretty easily... maybe two bolts??
Is this actually how you adjust the belt tension, or is there another spring-loaded tensioner in the system?
