New boat purchase
LateStarter
Vessel Info: 1990 Carved 38
Has thanked: 28 times
Been thanked: 4 times
Re: New boat purchase
Postby LateStarter » August 14th, 2019, 10:10 pm
Thanks. ColRon you certainly know your boat
ColRon wrote:Source of the post Latestarter,
Our 3867 Santego, Escape Plan, will cruise at WOT with a clean bottom at about 23-24 knots when all trimmed out, so she's no speed demon. but boy does she love to drink the fuel at that speed...about .5 miles to the gallon. :cry: I typically cruise on plane around 18-20 knots at around 3300 rpm. At around 7-8 knots I hardly leave any wake and will get just a hair above 1 mile to the gallon. :-D At 44 feet she's a heavy boat for gas engines and she would have been more fuel efficient with diesels, which Carver offered as an option beginning in 91, but I've never found one with diesels. That would be the only thing I would change, (switch to diesels) if I could afford to make the change and who knows, if I ever have to repower I might just bite the bullet. I have the Crusader Model 350, 454's engines, with velvet transmissions and Walter V-drives.
Here's a web link to the spec's on the 1990 Carver Santego for you. https://carveryachts.blob.core.windows. ... ego_90.pdf
Been thanked: 470 times
Postby RGrew176 » August 15th, 2019, 1:14 am
On a previous boat that I owned I blew an engine. The boat was in the water and the mechanic pulled the engine to do the rebuild and reinstalled the engine with the boat still in the water. I don't know if that is the normal process but in my case it was done while the boat was in the water.
LateStarter
Postby LateStarter » August 15th, 2019, 7:21 am
The boat is being moved, so I won't see it until Monday. Anyone know reputation of Galahad Marina in Northeast Md? That's where it is being moved for the engine install.
Postby tomschauer » August 15th, 2019, 9:33 am
Latestarter, not sure what going on there, but if the boat is at Charlestown Marina and they are moving it to Galahad, its a 10 minute move. Galahad (formerly Jacksons Marine) is directly across the northeast river, less than a mile.
A couple years ago Galahad bought two marinas in northeast. McDaniels and Jacksons. They had big plans to improve and expand. Both marinas are currently a shadow of their former selves, with a rotating door of employees. I believe Galahad has over extended themselves. If you have any say in where the work is done, look back at a previous post of mine on this thread for recommendations.
Postby bud37 » August 15th, 2019, 12:10 pm
LateStarter wrote:Source of the post I'll schedule the survey after my visual on Saturday. The seller is installing a new engine and will be moving the boat to a different marina. The one that has it now has been procrastinating rd the install. From my research it does seem to be a great price, hope it doesn't turn into a "if it seems too good to be true" situations. After you identified it as the 3867 model I located a youtube video about one in North Miami that showed a good walk thru. I'm really looking forward to Saturday.
Thanks for you help and info. :beergood:
So are they putting you off ??.....If it were me I would want to just see the boat, crawl around and go from there now, maybe you will find it is not for you and get it over with.....there should be no reason you can't see the boat before this move for engine work, which by the way can be done easily on that boat in the water, so long as the people that do the job are competent in completing all the aspects of the job correctly,.....not just simply changing the engine......good luck man whatever way it goes........ :beergood:
LateStarter
Postby LateStarter » August 15th, 2019, 12:40 pm
tomschauer wrote:Source of the post Latestarter, not sure what going on there, but if the boat is at Charlestown Marina and they are moving it to Galahad, its a 10 minute move. Galahad (formerly Jacksons Marine) is directly across the northeast river, less than a mile.
Thanks for the input. I am trying to contact the seller to see why he chose them to do the work and when he is moving the boat.
LateStarter
Postby LateStarter » August 15th, 2019, 12:48 pm
I don't know why I'm being put off until Monday, unless the seller is not going to be available because of the move. I had put in an offer on a boat in Florida that looked great in pictures and was supposed to be in perfect mechanical condition. The board's price was good & the offer was subject to a survey and trisl. When the offer was submitted, the seller revealed that the boat couldn't be sea trailer due to carburetor problems. Needless to say I withdrew the offer.
I' going to see if the seller will let me crawl around this weekend even without him there.
Postby tomschauer » August 15th, 2019, 12:59 pm
The owner of Charlestown marina can be a real D%#k. If the boats owner complained about the delay of installing a new engine, the marina owner may have given him 7 days to get out. He's like that. I wouldn't get near the boat without the owner if its at that marina.
LateStarter
Postby LateStarter » August 15th, 2019, 1:05 pm
tomschauer wrote:Source of the post The owner of Charlestown marina can be a real D%#k. If the boats owner complained about the delay of installing a new engine, the marina owner may have given him 7 days to get out. He's like that. I wouldn't get near the boat without the owner if its at that marina.
Seller told me that he had given Charlestown an ultimatum because of all the delays. He claims to have lost a couple of buyers due to the need to install the engine that has been sitting at Charlestown.
Postby tomschauer » August 15th, 2019, 2:30 pm
If he gave an ultimatum, im sure the marina owner told him to move his boat out of the marina.
Maybe make arrangements to look it over, and if it something you're interested in, call Tolchester and ask for a top end price to supply and install a 454 and deduct that from your offer.
I always liked the 38 santego, good luck!
