Power line 1 showing zero on the voltmeter
- jcoll
- Has thanked: 18 times
- Been thanked: 18 times
Re: Power line 1 showing zero on the voltmeter
- Has thanked: 314 times
- Been thanked: 585 times
- Has thanked: 432 times
- Been thanked: 1599 times
Unfortunately the shore power plugs we typically use aren't the best. There are better ones that you can upgrade to https://smartplug.com/ but you're still stuck with the traditional design at the marina's post. I'd take a look at all your external plug contacts from and including the shore power post, your Y cord, both cords, and inlets. If any contacts show signs of having overheated such as a discolouration where each contact goes through the housing or melting plastic, replacement is required. Don't underestimate the damage this can cause if it runs away. We tend to think that the breaker will trip when there's a problem....that's not always the case and the result can be catastrophic.
- Lyndon670
- Has thanked: 124 times
- Been thanked: 139 times
The only time I can run everything and not trip out is when my genny is running. At the dock on the post, I have to practise the power management that has been discussed here. Its especially problematic with summer in full pop with AC units running, hot water tank on, and trying to heat up something in the micro.
First world problems!
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
- Has thanked: 60 times
- Been thanked: 979 times
Won't solve the problem of running the microwave and coffee pot at the same time (which are on the same 15A circuit) but will stop the 30A breaker from ever popping.
- AaHubb
- Vessel Info: '99 404 CPMY
- Has thanked: 15 times
- Been thanked: 60 times
.. Aaron
SeaDragon
AaHubb wrote:Source of the post ....insulated carafe style coffee pot.....
That's the kind we use on our boat Aaron. Works great.
- peter.dein
- Vessel Info: 1995 Carver 370 Voyager, powered by twin Cummins 6BTA5.9-M2 (6 cyl 5.9lt) turbocharged diesels with 250kW @ 2600rpm, seawater after-cooled.
Re. 1995 Carver 370 with twin Cummins diesels -
After a successful engine start, I’ve noticed no alternator charge with the volt gauges sitting on 10v. Normally they display 13-14v. I shut down and then attempted to restart but there was insufficient battery grunt to crank.
My question - Is there an alternator fuse which may have tripped (I can’t find one), OR is it likely to be a sudden alternator failure.
Any advice would be kindly appreciated.
Possible relevance - I have large solar panels professionally installed which keep a healthy battery condition whilst idle on my mooring, however I think the alternator issue is separate?
Cheers
Peter
- buster53
- Has thanked: 8 times
- Been thanked: 256 times
- Helmsman
- Has thanked: 71 times
- Been thanked: 42 times
Viper wrote:Source of the post Power management is key so you don't stress the circuit and cause hardware issues over time. The breaker is an over-current protection device. If it tripped, there was either too high a load for the circuit or there is a problem with the circuit's wiring or hardware. Unless there was a dead short, the cause is usually due to running too many things at once. When you do that, you draw more through the circuit than it was designed for. This causes heat which starts to affect contact areas. Over time, the more compromised these areas become, the more heat is generated even with sub 30 amp loads.
Viper, I actually ran into that. This summer I had an issue with a pedestal in downtown Chattanooga. The real issue was the inverter batteries charging, the microwave being used, and AC’s on. We popped breakers. When I looked at the cords they were both “burn marked” on the pedestal side. Threw them away, bought new, and am now committed to power management.
Thanks for the tip.
Users browsing this forum: ColRon and 24 guests
