First time boat owner
- Gachong
- Vessel Info: 1977 Carver Santa Cruz 2866 7.3 diesel motor
- Has thanked: 11 times
Just picked up my Santa Cruz Carver today. 28’ long, 10’ beam, 7.3 Diesel engine, single screw. Boat is mechanically sound and needs some cosmetic work. Other than that, it’s just some touching up. Any recommendations that I should work on first? Also, where is the best site to purchase items or accessories specific for Carver rather than “universal”?
Re: First time boat owner
- mjk1040
- Been thanked: 248 times
As Hans mentioned, with the exception of a few things, every boat builder uses hardware from several manufacturers. As you're looking to add or replace things, post an inquiry here and I'm sure someone will chime in with some recommendations. Keep in mind that for safety reasons, some things MUST be marine rated, and for longevity's sake, some marine stuff is built differently than their non marine counterparts.
Ah, where to start? I would start with ensuring all safety related systems and items that can compromise safety are in proper working order. Then go over the engine and related/supporting systems in hopes of minimizing breakdowns; inspect and replace all fluids, filters, belts, impellers, check hoses, etc. Test the batteries and check the age of the charger, go over the electrical system, make sure your navigation equipment works, any obvious leaks that need to be addressed, etc. The list is endless. Oh and make sure the fresh water system and head/toilet work!
After the above is addressed, you can focus on cosmetic repairs or improvements.
Did you get a survey and did they find any red flags that should be looked after shortly.
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
- Been thanked: 491 times
- Gachong
- Gachong
Cooler wrote:Source of the post Welcome Skipper! Excellent advice from Viper, - safety, engine/transmission, and finally cosmetic. If you have the paper work from the previous owner(s), there is a list of all parts, as well as their OEM's. That is really the best source for replacement parts, as the vast majority of those companies are still in business. Carver always used high quality and high performance OEM's. If there is a marine store/shop in your area, stop in and introduce yourself. They can provide support in obtaining the correct parts the first time, instead of wasting time & money on the wrong part. Oddly enough, boat companies, engine and transmission manufacturers will use different ancillary parts on the same model core item. Really rare to find a diesel engine in that model. Any chance it was repowered by a previous owner?er
I am not sure. I will try and find out. I for one am happy it’s a diesel. I’m a big diesel fan.
- AaHubb
- Vessel Info: '99 404 CPMY
- Has thanked: 15 times
- Been thanked: 61 times
..Aaron
SeaDragon
- Cooler
https://carveryachts.blob.core.windows. ... 7/1977.pdf
