Mariner flooring project
Agriman
Vessel Info: 1998 Carver 350 Mariner Twin 454 Crusaders
Has thanked: 5 times
Been thanked: 4 times
Postby Agriman » December 23rd, 2014, 4:22 pm
I'm looking to replace the carpet in our 1998 350 Mariner with some type of wood flooring in the salon area. This area has 3 floor hatches to deal with. Has anyone done this with good success? I would love to see some pictures and get some ideas.
Lyndon670
Vessel Info: 2000 Carver 506
Volvo TAMD74EDC
Has thanked: 124 times
Been thanked: 140 times
Re: Mariner flooring project
Postby Lyndon670 » December 23rd, 2014, 4:52 pm
So, I did this with my Bayliner 3450 Avanti about 10 years ago and had the same issue. I came up with a work around that worked perfectly, was super easy to install - but was a pain in the ass to set up. I'll explain.
First, I went to the local dollar store and bought a pile of white 3x4 sheets of cheap bristol board (construction or project paper). I then laid it out all over my existing floor, trimmed the edges and used duct tape to join the pieces together. I removed the hatches in the floor and used an exacto knife to cut the holes into the bristol board where the hatches were. I used the exacto knife to cut around the bulkeads and built in furniture.
When I was done, I had an exact template of my floor. I then took this template home and stapled this template to 4x8 sheets of thin plywood and cut the plywood as per the template. I cut and glued laminate flooring ontop of the plywood, leaving the openings for the hatches clear. The I also cut a piece(s) of plywood to fit the hatches and cut and glued the laminate to the pieces of plywood on the hatches.
When finished, I was able to put the run of plywood/laminate flooring into the back of my truck, supported it with 2x4s and transported it to my boat. With the help of a buddy, I turned the floor template on its side and carried it into the cabin. I flipped it over and onto the floor and it was an instant perfect fit. The hatches were then dropped down into the holes. I screwed the floor down and was done. The beauty of doing it this way was that i could do all of the construction at home an dthe actual install at the boat was under 20 minutes.
Hope this helps!
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
Agriman
Postby Agriman » December 24th, 2014, 3:26 pm
Thanks Lyndon, I installed the laminate on the floor and cut out the hatches but I don't like the look of the hatches without some kind of borders around them. I did frame them but they make for good toe stubbers if not careful.
Thanks, Agriman
