erWelcome to Carver Yachts Owners Forum
Access to electrical under helm
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
Re: Access to electrical under helm
- Cooler
- Cooler
Here is a link, I think, to a pic of the helm.
- Been thanked: 490 times
Pull the helm chair off, take out all the screws holding the footwell in, remove the footwell, get a nice heavy blanket, lay it down over the sharp ledge at the footwell so you don't scratch up your back, lay down facing up , have a light source on, and hope you brought everything underneath you need.
While down there, clean the space; it'll need it.
- Cooler
Cooler wrote:Source of the post https://images.search.yahoo.com/search/ ... tion=click
Wow. If that's it, it's exactly like my 3607. Yes, just remove all those screws around the footwell (9, I think) and pull the footwell out. You can slide in there and look up at all the wiring. If you've never been in there before, plan for a bunch of extra time looking at whatever was done before, because some of it might look pretty "interesting".
I see what you have now. Ya the guys are correct, you'll get access through the foot well. Yes, be prepared for the worst. Certainly check all the electrical connections while you're there and correct deficiencies. Also ensure wiring is secured and that the stress isn't on any connection including display connection ports. I assume you have Hydraulic steering, it would be a good idea to check the fittings on the helm for leaks.
- Has thanked: 602 times
...just bring extra tools when you think you have enough......
