Eliminating Water Heater from Mercury Engine 7.4 MPI
- Mase
- Vessel Info: 1999 370 Voyager
- Been thanked: 6 times
Left the hoses going to the water heater in case we hook one back up and ran the new hose by the hoses and made sure the new hose was not coming into contact with anything that would rub a hole in it.
Pictures attached.
This also allows us to remove the old water heater and replace with something in the future.
- Has thanked: 432 times
- Been thanked: 1587 times
- Has thanked: 548 times
- Been thanked: 1145 times
Re: Eliminating Water Heater from Mercury Engine 7.4 MPI
Mase wrote:Source of the post Left the hoses going to the water heater in case we hook one back up and ran the new hose by the hoses and made sure the new hose was not coming into contact with anything that would rub a hole in it.
Looks good, If it were mine I would put new hoses to the new water heater when comes time. Once those old hoses sit dry in the bilge , rot will set in pretty quick.
Good you got the old one out, now could you reinstall a heater of the same size as the old by just reversing things?
- Has thanked: 256 times
- Been thanked: 1095 times
