Moisture Inside Distributor Cap - HELP!
- Sailorbanker
- Vessel Info: 1986 3207 Aft Cabin
We have added about 100 hours in the last 3 years. However, due to busy schedules, we used it very little in the past six months. My port engine started developing a ton of moisture inside the distributor cap. Replaced it (including new seal), added Wire dry/WD40, and it ran fine. Yet after a few weeks pulled the cap and was completely corroded. Again cleaned it, added wire dry/wd-40; Ran for a bit and died. Cap was full of moisture.
Ideas???
Never had a problem until recently.
Anyone using vented caps and if so, where can I get them? Thinking of venting the cap to a vacuum in the carburetor.
HELP!!!!!
- Been thanked: 490 times
Re: Moisture Inside Distributor Cap - HELP!
Moisture only collects on surfaces colder than dew point. Having said that, why is this one distributor colder than other things, and, where is all this moisture coming from? Do you have a wet bilge? A cooling system leak? Is the engine oil ok? Are the wires to the points sealed;the seal is almost 30 years old now. Are you using the exact correct cap? Is there a crack or hole in the distributor body? If it is this corroded, does the advance mechanism work or is it frozen by rust?
I don't have an answer but if it were me, I'd be checking the things I've questioned, starting with how sealed is the interior of the distributor.
- Been thanked: 654 times
agree any gas fumes exposed to some kind of arc would not be a good thing.
- Sailorbanker
oil is changed every 25 hours; caps are brand new after the first incident when started accumulating moisture. no coolant leaks. first time it happened was during the summer.
hmmm, looks like a worn seal.
thanks!
Users browsing this forum: No registered users and 40 guests
