89 Kohler genset won’t start
- CptBacardi
- Vessel Info: 1989 Carver 38 Santego (not an aft cabin)
- Has thanked: 3 times
Re: 89 Kohler genset won’t start
- CptBacardi
- CptBacardi
- ColRon
- Has thanked: 77 times
- Been thanked: 157 times
My understanding is that the Kohler L654 is a pretty robust engine and was used in several differing generator models. While it could be your magneto, some of the threads I’ve read on it on a vintage generator site, it is not common.
A word of caution, close your raw water valve before you turn over the engine a lot, as you are pumping water whenever the engine turns. In turn this water must exit via the exhaust system and without the engine running that water can back up and enter the engine through the exhaust valves.
That said, I would first pull the number one plug and with it removed and grounded, I would check for spark at the plug itself. If you’re getting a spark at the plug, then check each one. If they are all getting spark then it’s likely there nothing wrong with the ignition system.
You said earlier that the plugs were dry when you pulled them. It makes me wonder if it is getting fuel. If the problem were ignition related, I would expect wet plugs.
I wish I had an engine manual for the L654 engine...if it is determined that it is a purely ignition issue you will like need one to do any repairs/testing for the magneto.
“Escape Plan”
Murray, KY
- ColRon
https://drive.google.com/folderview?id= ... sp=sharing
“Escape Plan”
Murray, KY
- CptBacardi
- CptBacardi
- Has thanked: 603 times
Those pumps are completely rebuildable, but where to get one or a kit is a good question....the l654 engine has been around for a long time in lots of different machinery. Have you checked with any local generator dealers, not just marine .
I will add, your dry plugs usually shows a no fuel condition. Have a look at the fuel line from the tank to the pump, check for kinks, leaks etc.
- ColRon
“Escape Plan”
Murray, KY
- AnamCara
- Vessel Info: 2000 356
Crusader 7.4L MPI
7.3kw Kohler - Location: Delaware River and Northern Chesapeake Bay
- Has thanked: 10 times
