Green bilge pump indicator light
- BarryK
- Vessel Info: 1990 Santego 3467
Twin 454 Crusaders - Location: Oxnard, CA
- Has thanked: 12 times
- Been thanked: 6 times
1990 Santego 3467:
One of the bilge pump lights is not working. The pump and the float switch are fine. How do I remove and replace the light? What brand replacement should I look for?
Thanks,
Barry
- SplashyLady
- Captain
- Has thanked: 20 times
- Been thanked: 88 times
Re: Green bilge pump indicator light
You can replace it with your choice of color and style - but something like this (from Amazon):
Alpinetech 6mm 1/4" Green 12V LED Metal Indicator Pilot Custom Dash Light Lamp with Black Body PLB-6
or from eBay:
https://www.ebay.com/itm/PLB6-G-ATI-6mm ... Sw7aBVJCNX
Good luck!
Lake Norman, NC
Carver 3227 - "Splashy Lady"
- ColRon
- Has thanked: 77 times
- Been thanked: 157 times
BarryK wrote:Source of the post Hi all,
1990 Santego 3467:
Thanks,
Barry
Barry, if your 3467 is like my 3867, your talking about the indicator lights at the helm. They should be the same as in the circuit breaker panel. Check out this post for the part numbers. viewtopic.php?f=12&t=4485&p=32873#p32873
“Escape Plan”
Murray, KY
- Chaveros
- ColRon
Chaveros wrote:Source of the post 3467's and 3867's should be similar in this regard, right?
Yes, I’m pretty confident they are. Prior to Escape Plan I owned an 88 Santego 3067 and it used the same panel indicator lights. I know because I replaced them on it too. The only difference is that on my 3867, I upgraded and used the LED vs the incandescent.
“Escape Plan”
Murray, KY
- BarryK
Heading to the harbor today. I will try to get the old one out.
Barry
- BarryK
I was able to pull out the light. It started working again after I disturbed it! It is a Solico indicator lamp. I think similar ones are still available:
https://solico.com/products/round-indicator-lights/
I guess I will keep an eye on this and see if it continues to work.
Thanks,
Barry
- ColRon
“Escape Plan”
Murray, KY
- BarryK
Barry
- BarryK
I got the lights from LakeView Electronics in Wisconson. They are not expensive. It is a very good small company.
https://www.lvelectronics.com/#
I tried a Solico LED first but it was too dim. I then ordered an incandescent and it was much brighter, similar to the original. It was hard to see the LED in daylight on the bridge. I left the working lamp in place for the other pump.
Thanks again!
