Transmission Running Hot
- daviddodd
David
Re: Transmission Running Hot
Usually the raw water goes to the engine, then vdrive, then tranny. If you are low on water flow the vdrive or tranny will suffer first as the water is hotter when it gets to them. Is your impeller good? Then, is your trans heat exchanger fouled, then, not sure of your tranny, but is there a fluid filter and did you change that?
- mjk1040
- Been thanked: 248 times
- daviddodd
Mike. I did notice exhaust steam from the engine. Can you provide steps for descaling? Our lake is closed so it appears I will have time to do alot of maintenance work.
So my task appears to be 1. Check outflow of water at exchanger, 2. descale, 3. and then of all fails replace exchanger.
Please let me know if you other ideas.
David
- Has thanked: 603 times
You can back flush your thru hull raw water intake....maybe some plastic or growth in there.
Question....you changed the trans fluid, what color was the old fluid...nice pink like fresh trans fluid or shades darker ?
Finding an intact impeller in the pump doesn't eliminate the possibility of impeller pieces in the cooler from a previous impeller failure, though that isn't applicable to some cooler designs. It would also help to know the make and model of engines you have as not all coolers are built the same, and looking through a particular design doesn't tell you anything. Are these engines fresh water or raw water cooled?
If the transmission is indeed overheating and is not due to restricted raw water flow/volume, there may be a transmission issue and the condition of the fluid is important to note as mentioned. When does it overheat, and how long does it take? Does it overheat in neutral if you run her at 1500-2K rpm (no higher), or only in gear, and at what rpm do you need to achieve for that to happen?
A few other checks:
- Check to ensure that when you shift into gear, the lever on the transmission is fully engaged and can't travel any further.
- Check to see if there is any shaft creep (spinning in neutral).
- If the model has an oil filter, change or clean it depending on type.
- Is the fluid at the correct level and how are you checking it?
- Are you using the recommended fluid type?
- After a run, and while removing the dipstick, do you hear a release of air pressure?
Mike, I think you mean descaling the raw water circuit, not the "fresh water cooling system"
- daviddodd
