Need help with thrusters
- Bradorksy
- Vessel Info: Carver 30 Santiego
Re: Need help with thrusters
is back to the point that i cant get it out of gear . I have to use a lot of force to put it in neutral. Ill start with changing the throttle cables tomorrow because that's the only think i can do by my self after that i guess is call for some boat mechanic .
- Bradorksy
- Has thanked: 474 times
The shift cables from the helm to the engines will be the same as above in terms of brand and where to find the model and size. The lower shift cable from the engine to the drive can be either a Mercury or after market brand such as Sierra Bravo cable. Personally I prefer the Mercury cables.
Sounding more and more like a clutch problem though it's hard to say without knowing the condition of your cables. Every little bit of resistance introduced by each piece of hardware contributes to the overall amount of effort required to shift. With the helm cable disconnected at the engine, you should be able to shift the drive by disconnecting the lower cable at the engine and moving it in and out to shift WITH the engine moving. BTW, never try to shift a Bravo without the engine running.
- Bradorksy
- Bradorksy
Before disconnecting, make sure you take pics of how they attach to both the controls and especially at the carbs, where the throttle and shift cables separate. If not a three hour job will turn into four days.
- Bradorksy
The throttle cables will be longer than the shift cables and usually the port set of cables are longer than the starboard set.
There is a special tool used for setting up the lower shift cable properly as the adjustment needs to be precise for proper shifting. It can be set up without it if you know what you're doing but the tool makes it easier.
https://www.amazon.ca/Mercruiser-Bravo-Adjust-Adjustment-91-12427T/dp/B078PXDJYQ
https://www.amazon.com/Mercruiser-Bravo-865437A02-815471T1/dp/B07N146JDS
