1997 355 Aft Cabin aux tank
- chpsk8
- Has thanked: 27 times
- Been thanked: 76 times
Re: 1997 355 Aft Cabin aux tank
- True-North
- Vessel Info: 1997 Carver 355 Aft Cabin, lower helm station, Crusader 454 XLi engines, owner since 2007.
- Has thanked: 12 times
- Been thanked: 4 times
buster53 wrote:Source of the post When it's comes to the aft aux tank, either completely empty it or use it on a regular basis. What I do, if I take a trip, that will use, say 100 gallons, I run both engines off the aux tank to get there and use the saddle tanks to get home. Doing it this way, I quickly use up gas in the aft tank which lightens the weight in the butt end of the boat.
That is exactly my intent-use it very regularly. After removing the check valves, one had some build-up in it and the other was clean. It turns out the reason neither engine would run on the tank was because it was empty.
Stuck fuel sending unit float. All cleaned and ready to fill the tank again to see what happens!- True-North
Thanks everyone!
- True-North
