1997 355AC not able to pull from aux tank
- Saugatuck355AC
- Vessel Info: 1997 355AC
- Has thanked: 2 times
- Has thanked: 602 times
- Been thanked: 1310 times
Re: 1997 355AC not able to pull from aux tank
Are you sure there is fuel in the tank....you ran two engines off that tank for 3.5 hours, depending on what rpm that could be a lot of fuel gone. The natural answers are, the anti-syphon valve has become plugged or the tank vent could have become restricted, all things to check. Fuel gages are notoriously bad and the tank may not of got topped right up.
- bobkirkbride
- Vessel Info: 2003 Carver 444
bud37 wrote:Source of the post Well there could be many reasons for this, lets cross off some possibilities first.
I agree, maybe just no fuel left in that tank. Those mechanical gauge senders are notorious for being incorrect. A bad ground connection and it may show 1/2 a tank when in reality it is empty. Food for thought.
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
- Saugatuck355AC
- buster53
Before doing anything...check simple things first. Put 10 gallons of fuel in the tank. Just because the fuel gauge shows you have fuel, you may have a short fuel pickup in the tank.
Another easy check, after you put 10 gallons in the tank, leave the fuel fill cap off. That will tell you if you have a clogged vent.
After checking the easy things, then go after the more difficult. The anti siphon valve will be difficult.
- buster53
Viper wrote:From what I can remember, it's not that difficult to get to the top of the tank on a 355. I remember the top of the cabinet on the starboard side of the bed lifts off, and that the wall above the back of the bed comes off. The tank is behind there and the fuel connections are right there. The anti-siphon valve is the fitting on the outside top of the tank that your fuel hose is hooked up to. The sender is also there so I would test it to ensure it's working properly while you're there.
Yes, you are right, on my 356 the top does come off, but the framing of the cabinet still blocks you from getting close. I had my tanks emptied last year (bad fuel problems) and my fuel guy could not get close enough to the aft tank to be able to work on it. The entire cabinet frame needs to be removed first.
- Saugatuck355AC
Users browsing this forum: No registered users and 49 guests
