Removing saloon door
jfwatson3
Vessel Info: 2000 Carver 396
Postby jfwatson3 » October 31st, 2020, 9:54 pm
Hello,
I have a 2000 Carver 396 aft cabin, that has sliding saloon door and separate sliding screen. The track and wheels on the screen have become so fouled it does not easily open or close. So I need to remove the door and then screen to clean the track and probably replace the slide wheels. The question is how to best remove the sliding door. Referring to the attached pictures (
), I think the following will allow me to remove the door, but I'm not sure:
(1) remove the two sets of two screws from the top of the door to release from the top track wheels.
(2) remove a set of screws (looks like 3 or 4) along the bottom of the door to release from the bottom track wheels.
(3) the door does not look like it would have room to lift out unless the trim piece at the lower left of the foot well is removed; it appears to be removable with a single screw (and cutting the caulk).
The above is hoping that the seat above the door, the cabinet to the left of the door, or the stainless rail to the right of the door do not need to be removed in order to remove the door.
Any experience, ideas and tips appreciated.
Thank you.
--Jim
Agriman
Vessel Info: 1998 Carver 350 Mariner Twin 454 Crusaders
Has thanked: 5 times
Been thanked: 5 times
Re: Removing saloon door
Postby Agriman » November 1st, 2020, 9:33 am
Have you tried silicone aerosol lubricant's? It worked for me on our sliding door and screen.
Been thanked: 248 times
Postby mjk1040 » November 3rd, 2020, 8:29 pm
Clean what you can see and lube all you can, I wouldn't try removing that door unless I absolutely had to.
Cliffm
Vessel Info: 2006 Carver 36 MY
"the Condo"
VP 8.1Gi-F
Has thanked: 260 times
Been thanked: 21 times
Postby Cliffm » November 5th, 2020, 9:38 am
The lower rollers on or helm to salon door had collected numerous deposits. After scraping these off (one roller at a time 360 degrees, very tedious) and applying some silicon spay lube to the side rub rails, ours now glides back and forth.
Cleaning the rollers is much like cleaning the old roller ball mouse, scraping off all the accumulated residue.
hope this helps, good luck!
KyleR
Vessel Info: MV Verity
2002 Carver 396
Twin Cummins 6BTA 370HP
Has thanked: 153 times
Been thanked: 137 times
Postby KyleR » June 5th, 2025, 12:31 pm
I know this is an old thread, but I was wondering if the original poster, or anyone else, has actually removed this particular door that is found on the 396/404/444/etc models? Was the proposed method correct or is there anything else I should be aware of before attempting this?
I ran across some info a while back about someone removing this door and replacing the "plastic" slides with actual rollers. I haven't been able to find that thread yet, but I'll keep looking.
Thanks!
Kyle
MV Verity
2002 Carver 396
paulr
Vessel Info: 396 CY Aft Cabin 2001 8.1 Crusaders
Has thanked: 56 times
Been thanked: 32 times
Postby paulr » June 6th, 2025, 9:13 am
Hopefully there is an answer as to as to how to make this door easier to slide. On my 2001 396 the door very stiff to slide. As far as I can see everything is clean, there are no grinding noises and I sprayed it with silicon.
This subject is dear to me as I slightly tore a tendon in my should last August which at some point may require surgery from operating this door. I will do anything to fix this. Please keep us informed.
Carverlvr2
1979 Searay Sundancer 260
Been thanked: 25 times
Postby Carverlvr2 » June 6th, 2025, 12:32 pm
On my ‘04 366, that door is easy to open from the outside but a pain to open from the inside. Mine seems much simpler to remove and clean the track but I’m not sure if that’s really necessary. Does it just need some grease or new rollers…Waiting for someone with experience in this to weigh in.
KyleR
2002 Carver 396
Postby KyleR » June 7th, 2025, 3:33 pm
Here's my thread on how to do this:
viewtopic.php?f=7&t=8620
MV Verity
2002 Carver 396
