temperture control
- sassy
- Vessel Info: 1999 356 Carver Aft Cabin
temperture control
Re: temperture control
The generic space blanket is a very thin plastic film with very thin reflective mylar on each side, also used as a survival blanket. You can buy them very inexpensively:
https://www.amazon.com/ANMEILU-Emergency-Blankets-Survival-%EF%BC%8CMarathons/dp/B07GLCYR5S/ref=sr_1_2?dchild=1&keywords=space+blanket&qid=1609615190&sr=8-2
As Hans mentioned you can keep the a/c on when your away but that is a personal preference. It uses a lot of juice and a lot of run hours on the A/C.
I personally want to save those run hours for when we are on the boat.
- rcoff512
- Vessel Info: 1999 Carver Voyager 450
Home Port, Long Island NY USA - Has thanked: 12 times
- Been thanked: 8 times
- Contact:
Rich
- Has thanked: 474 times
Personally I'm not a big fan of leaving AC units running while away from the boat, I've been called to too many failures that caused floodings and near sinkings as a result. Most of us would never think of leaving the dockside water turned on while we're away for this very reason, leaving the AC on is no different. If you're lucky enough not to sink, depending on the location of the failure, repairing water damage to cabinetry and its brightwork can be a huge and expensive undertaking also.
- sassy
- Been thanked: 654 times
- Vector4
- Vessel Info: 1995 Carver 430 CMY
- Has thanked: 1 time
And just FYI my boat almost sank 3 days after I closed on it because the AC seacock lid bolt stripped out and burst open. So I'm veryyyyy familiar with the dangers! Nothing like a phone call when you are 5hr away that your hull is nose down.
'95 Carver 430 CMY
