New Mariner Owner
- Scott892
- Vessel Info: 2007 Mariner 360
Crusader 6.0 - Location: Chicago
- Been thanked: 2 times
New Mariner Owner
I'm aware of the cons of being slower and not exactly great at sea but a dock queen. I'm obviously ok with that trade off.
anything I should be aware of with this boat? Common issues? I was talking to guy with the same boat in my storage space and he mentioned he blows the fuse on his bow thruster all the time if runs for more than a couple seconds. Any idea what type/size of fuse this is? Anything else to be aware of?
Re: New Mariner Owner
No, it wont be as fast as your 28, unless it was a single engine 28, but it should get along pretty well with the 6.0's. It should also be more seaworthy than the 28 dancer.
The extra space and comfort will more than make up for any lost speed.
Enjoy!
A thruster blowing fuses all the time indicates there's a problem. Simply replacing the fuse or resetting a breaker without determining the underlying problem is not the answer. A unit that's working properly should not be doing that. Could be a number of things from wiring to a solenoid issue, motor, or mechanical problem. Typical causes though are poor connections or weak batteries.
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
- Been thanked: 1111 times
Agree with Viper's comments on the fuse. I'd check what model thruster is installed so you can make sure the current fuse is appropriate. You never know what some previous owner might have done that might be different than other installations.
- Been thanked: 490 times
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
- Scott892
Anyone traded in a boat before? Is this typical?
Users browsing this forum: Google Adsense [Bot], Midnightsun and 50 guests
