Shaft creep on a 356 2001 carver causes and remedies.
- schooner
- Vessel Info: 2001 356 Motor yacht
- Has thanked: 1 time
Re: Shaft creep on a 356 2001 carver causes and remedies.
What are you referring to as shaft creep? This is usually the term used for a shaft that is turning while the transmission is in neutral. Is this what is happening? If this is what you are referring to, what do you mean by 1/8th inch?
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
- Has thanked: 602 times
- Been thanked: 1310 times
schooner wrote:Source of the post Looking into a Carver and was told there is an 1/8th inch shaft creep on the starboard shaft.
I wonder if you mean end play....as in the shaft moves for and aft 1/8" ?
