1996 Santego 38 - Identification?
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 413 times
Re: 1996 Santego 38 - Identification?
Postby Cooler » July 7th, 2021, 10:34 am
Here is a link to the '95 380 Santego. I am 99% sure it is exactly the same as your 96. Carver used the same construction techniques for several model years. https://carveryachts.blob.core.windows. ... ego-se.pdf
Will answer several of your questions like thru hulls, etc. 8-) er
Cooler By The Lake
RixGutz
Vessel Info: 1996 Carver Santego 38 (I think)
Has thanked: 11 times
Postby RixGutz » July 7th, 2021, 12:48 pm
Same here. Sounded like seller was trying to play games. Don’t know the full details. I’ll hopefully be able to get over to the boat Brady week and get the low down.
ColRon
“Escape Plan”
Has thanked: 77 times
Been thanked: 157 times
Postby ColRon » July 7th, 2021, 12:54 pm
Welcome aboard!
Ron
“Escape Plan”
Murray, KY
:usa:
RixGutz
Postby RixGutz » July 7th, 2021, 4:00 pm
Yeah...I think it was the seller playing games. Didn't make sense to me especially with these super common engines. I don't know the details but I'll be going to the boat this next week and get more info. Thanks again for sharing.
buster53
Vessel Info: 2001, Carver 356
Has thanked: 10 times
Been thanked: 285 times
Postby buster53 » July 7th, 2021, 6:09 pm
RixGutz wrote:Thanks for all the replies. I really appreciate it.
Halfway through the manual, but it is very rudimentary. Is there anything that will show graphically where/how many through hulls and what types of sea cocks? Where everything is located on the boat (electrical panels, gray/black water tanks, etc.)? Or are there so many variants that you need to find them on your onw?
Forget the manual. Get a good flashlight and open every hatch there is, stick your head in and find/identify every thru hull, strainer, bilge pump, sump pump, etc. Follow hoses from end to end and figure out what each is used for. Carver is famous for placing bilge openings in hidden, out of the way places…look for them. Look inside cabinets, under stairs, under berths, etc.
Been thanked: 1111 times
Postby km1125 » July 8th, 2021, 8:42 am
buster53 wrote:Source of the post....
Get a good flashlight and open every hatch there is, stick your head in and find/identify every thru hull, strainer, bilge pump, sump pump, etc. ...
Good advice. Consider it a 'treasure hunt'!
When I first got my boat, I did this. Even before I actually bought it, I thought I had gone through and found every hatch. I didn't have a surveyor go through the boat, so I thought I was being "extra-diligent". After I got the boat I went through again and found a couple more access places that I missed.
Then the next year I found a couple more.
And the next year I found another one.
I was still finding one or two several years later! Some might require a screw or two to be removed, but others are just well hidden.
(P.S. BTW, I don't recommend buying a boat without a survey usually)
Cooler
Postby Cooler » July 8th, 2021, 8:59 am
That is great advice. Another reason to "explore" is you never know what a previous owner did, as a repair or customization. 8-) er
Cooler By The Lake
Users browsing this forum: Google Adsense [Bot] and 13 guests
