Need a Ac electrical diagram for pumps under galley floor for a 4207, 1988,
- bvcllc
- Vessel Info: 1988 Carver 4207 42 Ft. Two 350 HP Crusaders.
- Has thanked: 10 times
Re: Need a Ac electrical diagram for pumps under galley floor for a 4207, 1988,
I believe I would start from scratch, trace the piping and wiring and return it to the original configuration.
Do you know which pump is for which purpose? Looks like the one HVAC pump is drawing directly from the strainer and then it looks like a shower sump or bilge pump (in the lower left of the last pic). Not sure what the pump in the middle is, but it doesn't look like an HVAC circulation pump to me. Could it be a potable pump?
Oh, and are those yellow things twist-on wire nuts or crimped connections?
- bvcllc
- bvcllc
Is your AC water pump breaker at your panel turned on? And are you sure your pump actually works if power is applied to it?
- bvcllc
Why are those yellow and blue wire nuts there? If they were just temporary to cap wires and troubleshoot, then that's OK, but if the "electrician" put those on as a solution then you need a new electrician. Those should not be used on boats.
I suspect that red and black wire is not a marine-grade wire (probably not tinned). Do you know where this is connected? In one of the pics it looks like it might be spliced into the orange and black wires, but I can't really tell. I would trace this down and figure out where it goes... it does not look OEM.
Km is correct about the brown wires being standard colour code for bilge pump circuits. Check the two brown wires, one of them should have a black tracer if it's indeed bilge pump/float switch wiring.
The wiring really needs to be cleaned up once you figure out what is supposed to go where. And use the proper connectors, especially in the bilge. They should be heat shrink connectors as it can be such a damp and wet place. The heat shrink connectors will seal the ends so the wires don't corrode.
Users browsing this forum: Google Adsense [Bot] and 19 guests
