350 Mariner - some questions/comments
- feeez
- Has thanked: 52 times
- Been thanked: 64 times
Re: 350 Mariner - some questions/comments
- amanphoto
- Has thanked: 3 times
- Been thanked: 12 times
- Jerrygray
- Vessel Info: 2009 Carver Mariner 36M
RuffLife wrote:Source of the post We are in our second season with our 1999 350 Mariner. Overall we LOVE this boat and it is perfect for the type of boating we do.
The things we love most:The room on the flybridge is just amazing, especially after we had new canvas done in the spring that extends over the rear seat.
The amount of interior space/storage
Handles really well, as long as its not too windy
The shower!
Things that we don't love or find curious:The water that collects on the swim platform, stairs and swim ladder because it is nose heavy
The outlet at the helm on our boat wasn't working at first. Figured out that it is a GFCI outlet (as it should be) but the outlet with the GFCI reset is inside the bow storage area at the back of the helm where all of the wiring is. Not sure how one would ever get in there if you have the optional ice maker.
We have water that mysteriously collects in the furthest forward bilge area. There is a bilge pump in there but it can't remove all the water. Have driven myself crazy trying to figure out where the water is coming from
A couple of questions for other 350/360 Mariner owners:Has anyone taken out the existing carpet and galley wood floor and installed hardwood or something else in its place? We have two dogs and a cat on board and the carpet needs to be ripped out. Trying to work through the best option for a replacement floor covering
Looking to also possibly replace the cockpit and flybridge carpets. The ones that came with it are getting warn and if they get wet, they take forever to dry. Just removing them and having no covering isn't an option. With two big muddy shedding dogs, that nice white doesn't stay white for more than a few seconds. Looking at the wood look Nuteak (or similar) or the new Infinity woven fabrics that are really light weight and look like they would be easier to keep clean. Does anyone have experience with either of these?
Looking forward to hearing from others who are enjoying their Mariners!
Water in the forward bilge has always been from my Shower sump, when the pump fails.
- Jerrygray
- Has thanked: 314 times
- Been thanked: 583 times
- Has thanked: 59 times
- Been thanked: 969 times
Viper wrote:Source of the postamanphoto wrote:Source of the postIs there a way to pump fuel from one tank to the other? Is there a way to even out the two fuel tank volume?
There are fuel transfer pumps on the market that you could install to transfer fuel from one tank to the other. I've seen some Carvers with these so it may be a factory option. You can also even out tank levels by using the tank selector valves to draw only from the highest tank until the levels are the same and then switch back to isolate. I do this periodically as I use the generator a lot so eventually my port tank has less fuel than the other.
How are the fuel valves set up on the Mariners? On my older 3607, it was easy to switch either engine to either tank, or both engines to either tank. On some later models (356, notably) you could only switch from the main tank (port or stbd) to the Aux tank, so there was really no way to balance the tanks like I did on the 3607. That would have been annoying to me and I probably would have rigged another set of valves or a transfer pump.
- Has thanked: 550 times
- Been thanked: 1145 times
There are extra fittings on the top of the tanks for any optional use however.....would be easy to set up a manifold for the engines. Imo ,there really isn't enough fuel difference between the engines to require all the extra valving.
- Batwing
- Vessel Info: 1999 Carver Mariner 350
- Has thanked: 6 times
- Been thanked: 2 times
I have a 98 Carver 350 Mariner. Looks like there's a lot of suggestions for the water issue, but wanted to share a link to a former Carver 350 owner who I used to communicate with before he sold his boat. One of his projects was replacing the salon flooring, so it may be of help. Good luck and hopefully we can be of help since we have the same model Carver. I also recently posted a couple of forum questions for some interior salon issues. Here is the YouTube link to the gentlemen I mentioned.
