Mariner 420 2004 - water in swim platform
- Lruel
- Vessel Info: Mariner 420 2004
The core underneath the swim platform is delaminated on nearly half of the platform. My fiber repair guy is telling me that this is cuased by water getting in and out of the platform via the flaps at the end of the platfom. He suggest sealing these to prevent water from coming in after the repair is done.
My question is: if their are flaps at the end of the platform, it mus be because it is expected, by design, that there is water in the hollow platform. If so, does anyone know where that water could come from, if not from the flaps? Are there drains that are just connected to the hollow platfom? That would just fill it up if the flaps are sealed?
Any idea on how to fix this so that problem doesn’t come back?
Thanks in advance!
Laurent
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
Re: Mariner 420 2004 - water in swim platform
This may not be your issue, but this can be a problem.
Greg
- Been thanked: 654 times
- Lruel
There are compartments where the master cable is and some storage. Not sure if this is what you call a storage box?
Please check the picture of the back of the boat, you see 3 doors, this is where the storage area is.
For the flaps, I do not have a good photo but the second photo shows 1 flap on the starboard side (red arrow pointing at it). There a 2 other flaps, 1 in the middle and the other one on the port side.
Thanks again for helping me on this.
Laurent
- Lruel
Laurent
- Tireless
Water can get into your platform or deck anywhere there are screws or fasteners through the fibreglass. The water then wicks into the balsa core. The longer it is left, the worse it gets.
Greg
I would look for anywhere someone has made penetrations that were not factory. I see you have underwater lights, did the drill holes for those or anything else in the transom storage compartments and not seal them properly?
Hopefully, you can find the source of the problem.
- Lruel
I don’t think the lights are the issue since they are transom mount, a lot lower than the hollow platform.
I looked at what i could for the cockpit drains and they are connected to a drain on the side of the boat. But there may be other drains that i have not seen for sure.
The acces holes are actually vents connecting to the outside of the knee box at the rear of the cockpit.
Is there a way to get the plans from Carver? Understsnd their design intent?
I will definitely look for other drains coming in, but this means almost opening the platform on all its surface… kind of an expensive thing to do
Thanks for your responses and pls keep them coming, there might just be an idea that will spark from our discussion
Laurent
