Breaker Replacement
Postmaan
Vessel Info: 1996 Carver 355
Has thanked: 6 times
Breaker Replacement
Postby Postmaan » May 10th, 2022, 4:16 pm
My AC #2 on a Carver 355 keeps tripping the breaker switch. Does anyone know how to replace the breaker? Looks easy but not completely sure.
Re: Breaker Replacement
Postby tomschauer » May 10th, 2022, 9:25 pm
Do you have an amp probe? it's possible the breaker is bad, but more than likely an issue with the a/c unit.
Postby tomschauer » May 10th, 2022, 10:51 pm
Hey, another idea is to disconnect your a/c power into the panel. Move the wire from the a/c unit that is tripping the braker to the other a/c unit breaker. reconnect the a/c. If it trips that one, you can pretty much be sure it's the a/c unit not the breaker.
Postmaan
Postby Postmaan » July 20th, 2022, 10:00 pm
Thanks for the suggestion. Original unit and after following your advice I believe it’s done. Installing a new AC unit.
