E1 error code on AC/Heat
Jmgordon12
Vessel Info: 2001 530 Voyager Pilot house
Postby Jmgordon12 » October 25th, 2021, 1:15 pm
We have a 2001 530 Voyager (new to us). It has Webasto marine heat and air unit in the salon that keeps shutting down. Has a fault code of E1 (compressor high pressure protection). We cleaned the strainer, but it runs for a short while then shuts down. Any suggestions?
buster53
Vessel Info: 2001, Carver 356
Has thanked: 10 times
Been thanked: 285 times
Re: E1 error code on AC/Heat
Postby buster53 » October 25th, 2021, 3:38 pm
In the short time it is running, what kind of water flow are you getting? Do you have a strong flow? I assume one water pump handles several AC units. Strong flow from all outlets?
No issues with the other AC units?
Have you checked all your filters?
Mikwallace
Vessel Info: 1998 Carver 405 AC 7.4 Horizon engines
Has thanked: 117 times
Been thanked: 23 times
Postby Mikwallace » October 20th, 2022, 11:28 am
I know this post is almost one year old, but I’m having similar issues with my less than one year old salon hvac. Did you correct the issue??
1959 Larson 16’
1979 Caravelle 18’
:captain2:
:usa:
