1991 Original Battery Setup (33 Aft Cabin)
- Howell678
- Vessel Info: 1991 33’ Aft Cabin
Does anyone know what the original setup was from the factory? How many batteries and what was wired to what. I hoping someone knows to save me the time of chasing wires and with the chance it may have changed over the years. My house boat has a cranking battery for each egine and the generator. I replaced the old style charger with a modern 3 bank battery tender. It then has two house batteries that has a 12v powersupply/battery charger combo. I have been happy with this setup and I am thinking of doing something similar on the carver. I know there are two battery switched under the stairs coming into the boat, but I haven't even had time to see how many batteries it has (though it doens't look like their is room for 5 where they are located.
Any help is apppreciated before I start chaising wires.
- Has thanked: 603 times
Re: 1991 Original Battery Setup (33 Aft Cabin)
It may well be original, but will still require some looking into.....good luck with your investigations and hopefully someone with the same model can chime in.
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Some years ago, I had a 3807 and while we had the same 3 battery setup, if I recall, the battery compartment had room for 4.
I’m willing to bet $2 your battery compartment is designed for 3. FYI, my 356 is just a newer, slightly larger version of the 33’ aft.
As far as your genset not starting, my genset has its own on/off switch, similar to your basic, 1/2/Both/off, switch. Just maybe, that is your problem, switch not turned on…or the battery is dead.
