Engine Room Bilge
- ccanupii
- Vessel Info: 2003 Carver 444
Engine Room Bilge
Re: Engine Room Bilge
Don't drill holes in your stringers unless you know what you're doing or you'll create other issues. If they're cored strings and not properly sealed after you drill holes, it's just a matter of time before you need to deal with bad stringers. For the amount of times you'll actually accumulate water under the engines, I wouldn't touch the stringers, even if they're the hollow type as drilling through them for draining needs to be done correctly as well.
- Phrancus
- Has thanked: 16 times
- Been thanked: 136 times
- Contact:
practically I'd mount pumps or hoses to the lowest points and make it so that a pump is easy to connect when you want to clean/empty those areas into cannisters. Like you did with the shop-vac but then easier to get the job done as the hoses moving the wrong way is the usual irritation in that small area. Make it easy; rather than pushing it ahead for that free saturday morning next week next week next week next next.... oh, the bilge smells
- DanM
- Vessel Info: Carver 396
- Been thanked: 35 times
Carver 396
SugarSand Tango
- Has thanked: 602 times
- Been thanked: 1310 times
FWIW...the engine support stringers on our boat ( 01 350 Mariner ) were composite board material encapsulated with glass...the hollow stringers were forward of that.
I agree with paying attention to the bilge pump discharge quality, depending where you are there can be some serious fines for sheens. Bilge socks, pads and capture trays under the engines will help with that.
- ccanupii
To address the oil sheen issue, we spent two weeks degreasing the engine room. We have down a double layer of oil pads and will put a small oil boom around each pump to catch any oil that may be present. We also have replaced the older engine lights with 4 foot bright LED strips and there is no place that is hard see anymore.
I am sure this seems like overkill, but better safe than sorry and it is always give me peace of mind to know we have an emergency plan in place.
Thanks again everyone.
