3207 Carver fuel tanks
awelsh
Topic author - Scurvy Dog
- Vessel Info: 3207 1987 Carver
- Been thanked: 491 times
Re: 3207 Carver fuel tanks
Can't help you with your search; sounds like a big job.
- Been thanked: 654 times
http://www.sptanks.com/webdev/home.htm
- AaHubb
- Vessel Info: '99 404 CPMY
- Has thanked: 15 times
- Been thanked: 61 times
..Aaron
SeaDragon
I helped a buddy remove and install tank bladders on his Beach Duke.
If they hold fuel on a really nice aircraft they should work on a boat?
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
AaHubb wrote:Source of the post Edit.. g36 types faster than me...Since ethanol fuel eats fiberglass you might want to source an aluminum tank instead.
..Aaron
What he said.
waybomb wrote:Source of the post Had anybody ever tried a custom bladder to fit in a leaking tank?
I helped a buddy trove and install tank bladders on his Beach Duke.
If they hold fuel on a result nice aircraft they should work on a boat?
I looked into doing that on a tank that was simply impossible to replace whole without a major dismantle of the cabin. The problem I ran across was that there was no practical/safe way to cut out the baffles and ensure no sharp edges were left that would chafe the bladder. To do that, I'd have to cut away most of the tank which basically took me back to square one.
Do not use fiberglass for gasoline applications. Doesn't do well with ethenol apparently. Look for a plaque on the tank. It should have the OEM info on it. If you're lucky, they're still around and may have the diagrams on file to build another one.
Lots of knowledge on this site.
- SplashyLady
- Captain
- Has thanked: 20 times
- Been thanked: 88 times
While sourcing a quality aluminum tank for my last rebuild, they were the least expensive per capacity. They also offer a choice of wall thickness and powder coat if desired. Just measure your current tank, note fill, sender, and outlet connections - send them a sketch and you are good to go.
Contact Phil at Alloy Metal Works, 888-549-9353, New York state.
Get your quote....strike your best deal....they offer a ten percent discount off that quote for some boat clubs/members - doesn't ever hurt to ask! http://www.alloymetalworks.com
Lake Norman, NC
Carver 3227 - "Splashy Lady"
awelsh
