recently purchased 1998 carver Trojan 400 express. Ac compressor turns on blows cold air then trips breaker. No water coming from boat. Is there a valve I need to turn on ?Welcome to Carver Yachts Owners Forum
- MattyJ
- Vessel Info: 1998 carver Trojan 400 express
recently purchased 1998 carver Trojan 400 express. Ac compressor turns on blows cold air then trips breaker. No water coming from boat. Is there a valve I need to turn on ?- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 153 times
- Been thanked: 137 times
Re: 1998 carver Trojan 400 express
Kyle
2002 Carver 396
- Been thanked: 490 times
- Been thanked: 1112 times
Yep, find the water pump for the HVAC system and also the thru-hull and strainer for it. Make sure the strainer is CLEAN and that the thru-hull seacock is open. You might have to prime the system (make sure it's full of water) as they can get an airlock when the boat is lifted out of the water. Make sure the water pump runs and water flows out the exit when the AC unit is running.
Priming the unit can be done a number of ways. You can just stick a garden hose on the "exit" and force water "backwards" through the system to purge the air. You can also take the hose off the OUPUT of the water pump and run it for a few seconds to do the same thing. There are several other ways too.
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
