Replace wall covering
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
Also, the portholes. I have removed the screws, but the trim ring will not budge. Any tricks? The outer ring is held on the tabby’s and screws. I wat to get the inner ring off so the foam can go under the trim ring.
Just miffed how to get the entire sheet up with hitting it spot on teh first time, as there is no second chance!
Best,
Tony
Re: Replace wall covering
You might be able to do something similar, just using the backing paper of the self-stick. Leave that on and position the piece (maybe even tape it on the edges in convenient locations), then start peeling the backing paper off and sticking it down.
- tonyiiiafl
- Been thanked: 491 times
- tonyiiiafl
- tonyiiiafl
- tonyiiiafl
