Carver 396 swim platform rot repair
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 153 times
- Been thanked: 137 times
We are getting hauled out on Wednesday, July 5th which is when I'll start the bulk of work, but while we were tied up at the Oriental, NC free docks I went ahead today and cut all the silicone out and pulled everything apart and made preps for the actual work. Good thing too, as it took a lot longer due to screws that had been rounded off and I ended up having to grind a slot in them to get them out. Anyway, here's the first few pics showing the dock box coming off and how it is constructed. I'll keep this updated once we haul-out and I get going. Hope it helps!
2002 Carver 396
- paulr
- Vessel Info: 396 CY Aft Cabin 2001 8.1 Crusaders
- Has thanked: 54 times
- Been thanked: 32 times
Re: Carver 396 swim platform rot repair
I'm curious, what alerted you to the problem?
- KyleR
2002 Carver 396
2002 Carver 396
- Been thanked: 654 times
paulr wrote:Source of the post Oh boy, now I have another thing to worry about.
Another dock box issue. Everyone that has these mounted on their boat should pull them off check for any rot in the holes and surrounding area and reseal and/or fix before it continues. Mine has basically no sealant snd if the boat hadnt lived its life in a covered slip i would have had this same huge issue instead of a bit of rot around the deck screw holes. Carver did not do a through job in sealing these and at least you'll know where you stand before having to do a huge repair.
- KyleR
2002 Carver 396
This is the mess I found after peeling back the skin. Only took a couple of photos but you get the idea!!
2002 Carver 396
- KyleR
2002 Carver 396
2002 Carver 396
- KyleR
2002 Carver 396
2002 Carver 396
- KyleR
2002 Carver 396
The plan for tomorrow is to cut the plywood shape into pieces and slide them in like a jigsaw puzzle. Once the fit is right, remove the wood, lay down a layer of thickened epoxy, coat each piece of wood with straight epoxy and then put everything back in place, followed by a top coat of straight epoxy. I'll let you know how it goes!
2002 Carver 396
- KyleR
2002 Carver 396
I'm also posting a pic of the wood I used in case anyone else was wondering. Also, I ended up using 5 gallon water bottles filled with water for my "clamps". Worked pretty good!2002 Carver 396
