1995 325 Muffler blown
rbutler1959
Vessel Info: 1995 Carver 325, Twin 350 Crusaders
Has thanked: 2 times
Postby rbutler1959 » July 11th, 2023, 12:33 pm
I have a 1995 325 aft cabin with twin Crusader 350XL motors. The port side muffle is cracked and leaking. I searched the Owners manual and can’t find the part number or any reference to it. It looks like a Centek 1600507? The intake and outlet are 5”. Anyone know where I might find the part number and supplier?
Thanks…
Re: 1995 325 Muffler blown
Postby Viper » July 11th, 2023, 8:56 pm
That'll probably run you over $1K. I would be repairing it or taking it to a fiberglass shop to do it.
KyleR
Vessel Info: MV Verity
2002 Carver 396
Twin Cummins 6BTA 370HP
Has thanked: 153 times
Been thanked: 143 times
Postby KyleR » July 12th, 2023, 1:02 am
http://www.inetmarine.com/search.aspx?find=1600507
267-982-2192 John Boatman
Apparently they got all the prints/drawings for all the Centek stuff when they went out of business. When I had to replace two fiberglass components in my exhaust system, they had one piece in stock and the other they created based on the original designs from Centek. Not cheap, but good quality and pretty quick turn-around.
Kyle
MV Verity
2002 Carver 396
Postby Viper » July 12th, 2023, 7:00 am
KyleR wrote:Source of the post [url]....
Apparently they got all the prints/drawings for all the Centek stuff when they went out of business.....
Unless something just happened, Centek is still in business as far as I know. When did this happen?!
KyleR
2002 Carver 396
Postby KyleR » July 12th, 2023, 8:30 am
I misspoke.....as is typical! :banghead: I am trying to remember the back story I was told but it has been awhile. I think it was that when Carver went out of business, Centek at some point stopped making the parts and then Inetmarine got the prints and maintained the support. Or something like that. :confused:
Good catch - my memory ain't what it used to be!!
MV Verity
2002 Carver 396
Postby Viper » July 12th, 2023, 2:56 pm
....Good catch - my memory ain't what it used to be!!
Sorry, I forgot what you said ;-)
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 413 times
Postby Cooler » July 13th, 2023, 12:45 pm
Yep, easiest way is to have a fiberglass shop rebuild it. Friend of mine just had the same issue, could not find replacement. That was a 94 Sea Ray. Good luck! 8-) er
Cooler By The Lake
Aj325
Vessel Info: 1996 325 Aft Cabin
350 XL's
Has thanked: 4 times
Been thanked: 2 times
Postby Aj325 » May 20th, 2025, 6:16 pm
Hi,
I have a 1996 325 aft cabin with Crusader 350’s. I believe the muffler drain is leaking on the Starboard engine.
I tightened it by hand, maybe 1/8 turn, but it is still seeping. Can you tell me if the seal is an “o” ring, or what brand the muffler is?
Currently the muffler is full of winterizing antifreeze, and I think I will wait until after launch so when I pull the drain it is just fresh water I need to clean up. My boat is in Manitowoc, Wi.
How did you resolve your leak on your muffler?
Thanks!
Allen Dietrich
paulr
Vessel Info: 396 CY Aft Cabin 2001 8.1 Crusaders
Has thanked: 56 times
Been thanked: 32 times
Postby paulr » May 21st, 2025, 5:06 pm
I had blown muffler once. The cylindrical fiberglass tube connector that connects the rubber exhaust tube to the muffler cracked and allowed the engine cooling water to pump into the bilge. I didn't have bildge alarms and the bildge began to fill with water as the bildge pumps would not keep up. Once I discovered it I shut down the engine and went the the marina on one engine.
Once I got the muffler out, I cut off what was left of the fiberglass tube from the muffler and simply put resin every where the tube connected to and put 3 layers of glass mat over it and soaked it with resin. the repair was perfect. Stronger than new.
The joint failed because it overheated due an almost fully clogged exhaust elbow.
I bought the connector from Defender Marine.
