350 Mariner - some questions/comments
- Been thanked: 490 times
Re: 350 Mariner - some questions/comments
I'd be very careful installing one of those clamshells.
RuffLife
Topic author - Scurvy Dog
- Vessel Info: 1999 Carver 350 Mariner
- Has thanked: 5 times
- Been thanked: 6 times
We were out on Sunday but very calm water so not the best test environment. Our club has a cruise this weekend to another club. Won't be covering a huge distance but should be pretty choppy out there. Might be a better opportunity to test it out. Makes perfect sense to me though that this might be the culprit.
zero
- Vessel Info: 2000 350 Mariner
So I thought I would tag along in this thread and ask a question of my own:
I noticed that when going at 15 knots or so, my fuel gauge reads almost a quarter tank lower than what it reads when at idle speeds. Is this due to tilt of the tanks? Should I be going by what the gauge reads at low speeds? It can be a bit disconcerting when looking down at your fuel gauge and seeing the needle pointing at E.
After Taxes
- Vessel Info: 'After Taxes'
2004 Carver Mariner 360
Lake Simcoe & Georgian Bay,
Ontario, Canada - Location: Lake Simcoe Marina
- Has thanked: 6 times
- Been thanked: 17 times
Did two more runs with duct tape covering the forward bilge pump discharge thru-hull. The forward bilge area stays completely dry.
MerCruiser MX 6.2
Lake Simcoe, Ontario
TonyC
- Vessel Info: 1998 Carver 350 Mariner
- Has thanked: 22 times
Did you figure out how and with what to replace the carpet. Been thinking about removing the carpet and laying down simulated wood laminated vinyl covering but not sure how it would hold up on marine environments. Thoughts?
Also, what propulsion system do you have? Ours is equipped with Merc 350 MAG EFI ... 450 hours.
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
mattisk
- SplashyLady
- Captain
- Has thanked: 20 times
- Been thanked: 88 times
mattisk wrote:Source of the post Im looking at a 1998 carver mariner with merc 7.4 MPIs. Test ran yesterday and port had 3300 rpms and the starboard had 3500 Wot maxed out at 18.2knot. Anyone know what is normal?
You do not specify which model/length you are referring to, but that seems slow for that powertrain for the typical 32-36 foot range Mariner. She should run upper 20s to near 30 at around 4500 RPM.
Lake Norman, NC
Carver 3227 - "Splashy Lady"
- Hugo
- Has thanked: 2 times
- Been thanked: 23 times
After Taxes wrote:Mariner Forward Bilge water follow-up;
I would take a look at the hose going to the thru hull and check that it has a vented loop well above the waterline. Sometimes it's just a cable tie holding the loop there and it may have broken off...
- Wkuhilltopperfan
- Vessel Info: 1998. Mariner 350 . Twin 7.4 engines / kholer 6.5 gas Genset
- Has thanked: 17 times
- Been thanked: 18 times
Mine is covered with growth right now and slows the top speed dramatically and makes getting on plain difficult as well. When I first splashed mine with a clean bottom, my top speed was around 28 mph with twin 7.4l's
Users browsing this forum: No registered users and 193 guests
