Engines smoking but running well
1996 Boston Whaler Rage 15 - Location: Saint Joseph,Mi
- Has thanked: 50 times
- Been thanked: 399 times
Re: Engines smoking but running well
- Seif911
- Captain
- Vessel Info: 1977 Carver Mariner 33'
- Been thanked: 3 times
Maybe it is just too much unburned gas? If that is the case, it just may be the carb/plug problem you previously described. Maybe it is dropping to much un-atomized gas in the engines? Maybe the carbs need a cleaning since they sat for 5 yrs? That could possibly affect both engines since they sat the same amount of time.
To that point...I know the blowers are working but did not actually check the flow of air. Possible problem...lack of air?
The distributor does not look original. It is a pretty 'Mallory' distributor and very clean inside. I doubt this would be a problem. The wires are also all brand new. I guess I should maybe change the plugs out.
We'll see if the new fuel filters help at all. I suspect not.
This is a good one! I appreciate all of the thoughts and hopefully we'll figure this one out.
Steve
Exhaust from a boat shouldn't smell much different from automotive, just a little wet.
If you are smelling gas, id say buy two carb kits and rebuild them.
Have you done quadrajets before?
- Seif911
- Captain
Steve
- CYO Admin
- CYO Administrator
- Has thanked: 269 times
- Been thanked: 26 times
- Seif911
- Captain
Steve
- Seif911
- Captain
So I have taken the boat out quite a few times now. The white smoke comes from both engines. It really has no steam mist at all and I am pretty sure it is white smoke. It seems to be getting a little bit smaller. It does not smell like oil, maybe a little like gas. I have a feeling it is the very bad gas I have. I am just too going to keep running it with a close eye on it.
Steve
- Vessel Info: 1992 Carver 538 Montego
Twin 454 Crusaders
Updated Electronics
I'm second owner! - Location: South Haven Michigan
Took my boat out for a ride as well this week, white smoke/steam as well equal on both sides (pretty light) But Lake Michigan water temp is 53 degrees and air temp was about 70! looks pretty normal as cold water,hotter exhaust. I had put in about 60 gallons of fresh gas and Lucas (which helps)
Temp at 180 on both 454 Crusaders with CC, Oil at 40, all and all for a 20 year old boat and engines not all bad....also FYI GPH was about 14!
Boat safe ! Boat Often!!
Jim
- Seif911
- Captain
Well that is good to hear. It is definitely some cold water. I like the GPH. Was that an aftermarket addition to read that?
Steve
Users browsing this forum: No registered users and 40 guests
