83' 3207 AC question
Topic author - Scurvy Dog
1996 Boston Whaler Rage 15 - Location: Saint Joseph,Mi
- Has thanked: 50 times
- Been thanked: 399 times
Re: 83' 3207 AC question
I think total BTU was 45,000 or so on the 4207 and one pump handled it all. The water being discharged doesn't get too warm either.
- CYO Admin
- CYO Administrator
- Has thanked: 269 times
- Been thanked: 26 times
- Vessel Info: 1983 3207 aft cabin
I had an odd situation once on vacation - I sucked a plastic grocery bag into the through hull pick-up and my a/cs quit running on overheat. I pulled the hose, with water gushing in, trying to free the bag. That didn't work. So I took it back out on the lake thinking that would remove it. That did not work, so I had to have somebody jump in the water and dig it out of the through hull grate.
- Vessel Info: 2006 Voyager 560 with twin D12-675 volvos
If you can get to the units and feel the outlet hoses they should both feel about the same temperature; if one is much hotter you have a restriction.
As others have said one pump for multiple units is very common the system just needs to be maintained and flushed from time to time. NOTE: in the Galveston bay area my system needs to be flushed twice per year.
Dan
Users browsing this forum: No registered users and 6 guests
