Generator Kohler model 9C63 and Air conditioning
- Brunos
- Vessel Info: Carver 38, year 1990
Since the day they took to boat out of the water I'm also having issues with the air conditioning. I turn it on and I get message STAND BY a few seconds after the air conditioning starts and a few second after I get the message FLT DLY HIGH PS.
I'm assuming again it has something to do with the boat being taken out of the water, how do I resolve this. It was working before the lock system.
I did go down under where the motors are and found 6 valves connected at the bottom of the hull. I tried to close them and open them but the problem is out of the 6 I was only able to open or close three, the other are all seized up and I mean can even bring the handle down, I thought I was going to break one so I stopped.
hopefully someone will be able to help.
thanks in advance.
RS
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 153 times
- Been thanked: 139 times
Re: Generator Kohler model 9C63 and Air conditioning
However, going forward, one thing you can do before getting "hauled out" (for a lock, going on the hard, bottom job, etc.) is to close all your seacocks before getting lifted out so you keep the pump suctions full of water. Just don't forget to reopen them before starting the various systems after launch. But, that assumes all your seacocks can be closed, which is another issue you've got to deal with.
Remember, the ability to close each seacock is critical to keeping your family/boat safe if one of those seawater lines fail/rot/rupture/etc. Do some searching on here and you'll find several good ideas to hopefully unstick and free up those valves. Don't do like me and force a valve too much and snap off the handle! That ended up costing me a haulout and seacock replacement. Luckily it was a DIY job but still a major inconvenience!!
Good luck!
2002 Carver 396
That won't work for the genset though. However, the genset should prime itself. You might have an issue with the raw water pump impeller on the genset. If you haven't changed it yet, you probable need to track one down and change it. You might be able to get by with priming it but you'll likely have to take a hose off on the genset (probably after the water pump and could even do it after the heat exchanger) and pour water into it until it's full. That would likely bleed backwards down to the raw water pump and prime it. But you should still plan on doing an impeller replacement.
If it's a new-to-you boat, you should also plan on doing the main engine impellers too, so you KNOW for a FACT when they were last changed. They are one of the most common causes of a ruined weekend when old ones fail unexpectedly.
And as said earlier, you definitely want all those seacocks to be working correctly.
- Has thanked: 603 times
What you have experienced is a common issue when you transit the big chute ..... really the seacocks for the air should be closed before the carriage moves. generally the engine and generator are ok, or at least in my experience.
The others are correct you have lost the prime and the gen sounds like maybe the impeller has been damaged or just worn out, those seacocks should all be working.
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Just slightly open up your strainer until the hose between the seacock and the strainer fills with water and starts coming out of the strainer. The air bubble that causes your problem is usually in that section of hose. Opening the strainer allows the air in the hose to escape.
- KipW
- Vessel Info: 1988 Carver Mariner 3297
- Has thanked: 6 times
- Been thanked: 2 times
Kip
