2000 374 carver gear oil
333
Vessel Info: 2000 carver 374 voyager
Postby 333 » September 29th, 2024, 3:01 pm
Carver model 374 with cummins 330 hp diesel engines. What oil is used in transmission gear box. It smells like engine oil differently not gear oil [ 80w90 ]. I have checked through manual that came with the boat but doesn't mention grade of just that it needs to be checked. I would be grateful if someone on here could answer this question. Thanks
Re: 2000 374 carver gear oil
Postby km1125 » September 29th, 2024, 7:33 pm
If you put the make/model of the transmission in the thread you'll get better responses. The same unit was probably used on other models but unless a member has specific knowledge with your year/model/power_package you're probably not going to get good responses. Some do use regular engine oil and some use transmission fluid.
Postby Viper » September 30th, 2024, 7:03 am
Could be straight SAE 30 but you need to confirm the manufacturer's recommendation. Knowing the make and model would help.
Postby bud37 » September 30th, 2024, 12:58 pm
333 wrote:Source of the post Carver model 374 with cummins 330 hp diesel engines. What oil is used in transmission gear box. It smells like engine oil differently not gear oil [ 80w90 ]. I have checked through manual that came with the boat but doesn't mention grade of just that it needs to be checked. I would be grateful if someone on here could answer this question. Thanks
My advice , get the serial number and model number off the trans I.D. plate and e mail the manufacturer to ask what oil/fluid they installed from new around 2000. They are straight drives , correct?
Postby bud37 » October 1st, 2024, 12:51 pm
I know there has been no response yet but felt to add some needed info for others maybe caught in the same issue.....I know it happened to me, caused a huge problem and expense.....
To add to the above.....it is important to use the correct compatible fluids in these applications. Over time builders change their specs and shaft seal etc materials which can be affected by different fluids. Some fluids have seal conditioners etc to help performance to stop leaks, perhaps a different viscosity etc.
That is the reason to get what the manufacturer of the unit recommends for those year builds.
KyleR
Vessel Info: MV Verity
2002 Carver 396
Twin Cummins 6BTA 370HP
Has thanked: 153 times
Been thanked: 138 times
Postby KyleR » October 1st, 2024, 12:54 pm
I have the ZF 280A transmission and use Shell Rotella T1 30W, which was recommended by the guys at boatdiesel.com and sbmar.com.
Kyle
MV Verity
2002 Carver 396
333
Postby 333 » October 6th, 2024, 4:34 pm
i contacted manufacturer and they said to use a sae 30 weight for summer use winter they recommend a sae 10
Thanks all for the help
