Tides sure seal hose routing
anothernewb
Topic author - Scurvy Dog
- Vessel Info: 2000 350 Mariner
Twin Mercruiser 5.7l Horizon
Garmin 4212 - Location: Space Coast Florida
- Been thanked: 21 times
Port exhaust riser_____prop seal____prop seal____????
Can any of you fill in the blank. Only one riser has a nipple for the hose to the water seal. I've checked all the manifolds and risers and can't find another.
Re: Tides sure seal hose routing
- Ramsport47
- Has thanked: 72 times
- Been thanked: 59 times
T-Merc 350 Mag MPI (300hp)
I haven't had a chance to confirm yet but I seem to recall a Mercruiser bulletin about not hooking up the two seals to each other. If I remember right, this came about as a result of engine water intrusion. The reported faults happened as a result of the following; when heading back to shore on one engine after the other failed to run for one reason or another, water that was discharged from the running engine's exhaust through the dripless shaft seal on that engine's side, would as it was designed, also feed the opposite side that had the failed engine. The issue was that the exhaust water going through the failed engine's shaft seal would carry on through the seal and up to the engine that wasn't running as it would not encounter any water pressure from the non-running engine. Somehow, under the right running conditions, water would enter the exhaust side and run into any cylinder who's exhaust valve was in the open position. Merc's suggestion was to isolate the two seal assemblies by capping of the ports leading to the opposite seal. Maybe someone with a better memory than me can confirm (or deny).
anothernewb
Anyone with a 350 Mariner want to take a peek in their engine room and check for me?
