Bilge pump wiring
Twobuoys
Vessel Info: 1988 3257 sedan mercruiser 5.7 power
Bilge pump wiring
Postby Twobuoys » March 25th, 2025, 6:45 pm
I just purchased a 3257 1988 carver Montego sedan I’m trying to fix wiring problems. The switch panel indicates two bilge pumps. However, there are three bilge pumps, the aft bilge pump and the mid cabin bilge pump both work as designed the forward bilge pump has two wires, and there is no power Have a good ground wire but the positive wire is dead I’m trying to figure out where it goes. Any suggestions? Thank you.
Carverlvr2
1979 Searay Sundancer 260
Been thanked: 22 times
Re: Bilge pump wiring
Postby Carverlvr2 » March 25th, 2025, 7:05 pm
Power for bilge pumps should always come from the batteries with a breaker in between. My bilge breakers are under a step. Make sure those are all on first. Then trace back to the pump from there.
Has thanked: 469 times
Been thanked: 1765 times
Postby Viper » March 25th, 2025, 7:38 pm
Welcome aboard. Does your forward bilge pump come on when the mid cabin pump is powered up? They might be on the same circuit. I've seen them hooked up this way before.
Twobuoys
Postby Twobuoys » March 28th, 2025, 12:51 pm
Thanks for getting back turns out the forward pump is a stand alone has no switch and runs straight from main battery breaker found a push button breaker in the back of a locker under the helm seat reseat the breaker easy peasy works now
Postby Viper » March 28th, 2025, 5:40 pm
Glad you solved the problem. Is that pump hooked up to a float switch?
Twobuoys
Postby Twobuoys » March 28th, 2025, 6:50 pm
Yes new pump new foot switch
