Just something for those of you that use rotella on your gas engines.
- Been thanked: 601 times
- Has thanked: 59 times
- Been thanked: 479 times
Re: Just something for those of you that use rotella on your gas engines.
I have used Rotella plus some GM EOS for many years. Many. In all my engines other than my Benzes.
No issues.
No issues.
- Has thanked: 597 times
- Been thanked: 1281 times
Wow ....some dramatic huh, Honestly I wonder who is paying for that ? or just another influencer. Its oil for gosh sake....if it was that bad there would be more lawsuits than ya could imagine.....
- Been thanked: 1179 times
Put me on the list of users that has used Rotella for the last 25+ years on gas engines which includes my PWC and convertible Benz SL. Never had and issue whatsoever. In fact my previous boat now has close to 2000hrs on her 357 mags and still purrs like a kitten.
- Has thanked: 467 times
- Been thanked: 1763 times
As I've mentioned MANY times in the past here, I'm not a fan of using diesel oils in gasoline engines. The chemistry is different in both applications for good reason. Not having had a problem up until now using the wrong oil doesn't mean it's ok to do so, it just means the conditions so far have not caused a failure.
The oil debate is deep
Let's leave it there?
EXACTLY! Nobody's going to change their mind on what's been working for them so far. Good to put it out there none the less, thanks Tom.
One thing for sure , " It's a slippery topic. ".......
- plittle2005
- Vessel Info: 1992 Carver 350 Aft Cabin
- Has thanked: 16 times
- Been thanked: 36 times
Rotella or equivilant, is required for flat tappet engines, up through 1995, for the anti-wear zinc and phosphorous content.
Oils without, used in these engines, will cause excess wear and destroy the engine.
Some of the zinc had been removed from Rotella. Fkat tappets need some extra zddp.
I use the old GM EOS which you can still find on ebay.
The old ones, not in the plastic bottles, but the cardboard type.
Users browsing this forum: No registered users and 122 guests
