"Help" Carver Repair Quote
Topic author Italy
Bankerbiz87
Vessel Info: 1982 Carver Mariner twin 220 engines 28ft
Has thanked: 10 times
Postby Bankerbiz87 » April 30th, 2016, 12:55 pm
Recent quote from Mechanic to replace stuffing box flax material quote 1000.00 because of in accessibility of stuffing boxes. Propeller and shafts have to be removed the motor mounts loosened and engine to be raised to service stuffing boxes. Please advise on the accuracy of this quote. Thank you!,
SplashyLady
Has thanked: 20 times
Been thanked: 88 times
Re: "Help" Carver Repair Quote
Postby SplashyLady » April 30th, 2016, 3:10 pm
Unlikely. Can you post a picture of the stuffing box area? A pic is worth - a thousand...
Captain John
Lake Norman, NC
Carver 3227 - "Splashy Lady"
Ramsport47
Been thanked: 59 times
Postby Ramsport47 » April 30th, 2016, 4:18 pm
The boat has V drives. I can see them being hard to get to, but not where you'd have to remove the shafts and loosen the engines.
Kenny
T-Merc 350 Mag MPI (300hp)
Postby bud37 » April 30th, 2016, 5:59 pm
Well, I had an 83 28' mariner with the v drives mentioned above and replaced the packing.....now it is a miserable job which includes mirrors etc and working with one hand thru the cabinet on one side , but I have to say an experienced tech should not need 10 hours for that job, and there was no moving engine mounts etc....so that being said maybe the 81 is different, but that is my two cents......
Postby Viper » April 30th, 2016, 8:53 pm
Those are terrible to work on because of the V Drives but it is totally doable without all that dismantling. Haven't had to go through that much work yet to replace packing. It's tight and I don't envy the poor guy that will be tasked with it but he'll live!
Been thanked: 248 times
Postby mjk1040 » May 1st, 2016, 7:23 pm
Seems high to me, if you can see the stuffing boxes and put your hand on them u should be able to remove and re-stuff them. Are they leaking a lot? If you can put up with a small dripping you should be fine, have you tried just tighting them a little or are you out of threads? The right side motor will most likely be left hand threaded. Picture would b great. If one has to raise motor mounts and remove shafts, etc, then re-alignment needs to be done. Shop around and find another mechanic.
Mike
NextPhase
Vessel Info: 1993 Carver Voyager 350
Has thanked: 3 times
Postby NextPhase » May 1st, 2016, 10:03 pm
I would get several quotes. It seems very high for someone that would know how to do it :-(
