Just something for those of you that use rotella on your gas engines.
Re: Just something for those of you that use rotella on your gas engines.
- Has thanked: 602 times
Viper wrote:Source of the post especially hotter running marine engines.
Heh the horse lives....like that Schrodinger thing
... yep, but don't marine engines run cooler... raw water cooled thermostats spec at 142 or so in salt.-
Let me get off the horse already
Viper wrote:Source of the post Zinc does help with lubrication but has side effects at higher levels in gasoline engines
I fully agree,..... one point to consider in this though , diesel combustion chambers run at much greater temps than gasoline due to the fuel and compression almost two times in some cases.
W The fact of it is we used the zinc to protect the valve train in flat tappet engines like has been mentioned. Now all the gas engines are roller as far as I know and have been for some time now so no need. Too many opinions out there including mine and yours.
Looks like the saddle has some glue on it...
One must specify which Rotella one is referring to because this Rotella is recommended for Diesels and Gasoline engines.
https://rotella.shell.com/en_ca/product ... 9lbl9jYQ==
Should also mention regular T4 Rotella IS SN rated. What is the SN rating? The newest standard for gasoline engines as can be seen here and does cover engines . https://www.gopurepower.com/blog/a-guid ... motor-oil/
Check out the spec for Rotella T4 oil (SN Rating) here. https://www.traction.com/en/p/rotella-t ... e550045128
OK, we can kill the horse once more.
