Old exhaust system
- Kruggy88
- Vessel Info: 1991 carver 638 santego
Old exhaust system
I just pulled the port Crusader 454 out of my 1993 carver 638 santego. My engine got hydrolocked and it appears I did some bottom end damage. Hoping to confirm it next week.
I am fairly confident the water ingress was from the intake manifold. I have always had water drain from tithe cockpit floor onto the cover of the carb but we had some major rain storm and it must have leaked enough water to fill a cylinder.
I am preparing for the rebuild and starting to think about replacing exhaust system or keeping the old ones. The exhaust ports on manifold, riser, and elbow are completely dry but I have every reason to believe they are original. I have a raw water cooled boat that has spent its entire life in Wisconsin boating on fresh water.
My mechanic said if they look good than it’s not worth the $2000 to replace. From everything I hear on the internet, it sounds like it is completely nuts to put 33 year old manifolds, risers and elbows on a freshly rebuilt engine. I don’t know how much I will be into the rebuild but I am assuming at least $5000, so I would love to save money where I can but the last thing I want to do is blow up the motor again.
I was hoping to get some opinions from seasonal fresh water boaters that have or haven’t replaced their exhaust system.
- Been thanked: 490 times
Re: Old exhaust system
No issues
- Kruggy88
- Has thanked: 602 times
So my opinion here....it is one thing to be thrifty but in this case the least you could do would be to have them pressure tested and gasket surfaces cleaned and levelled , even at that you can't see the inside passages which can be where the pinholes and water comes from many times, plus at this point you really don't know how the water got in there....may have been reversion or ?? just sayin.
Brand new engine deserves new stuff, too expensive to cheap out and put ancient parts back on, not just precautionary but wise.....good luck with your refit.
Carverlvr2
- Been thanked: 25 times
- Kruggy88
Water coming in thru the carb to flood the intake manifold is the only things that makes sense. The engine did not over heat, I didn’t make an abrupt stop nor take a big wave to the transom.
- Kruggy88
Engine has ran great all season, no sputtering, no hard starts.
- Kruggy88
I've found over the years that with SOME things, one's thinking has often been backwards, it's not that you're saving $2,000 by using your old exhaust, it's that you're spending $2,000 to avoid another $5,000 bill for another engine should the old exhaust fail, not to mention another blown summer. Oh, the other thing I always say is "pay me now or pay me MORE later." That consequence of taking shortcuts never fails!
Having said all that, you need to do something to prevent water from getting into your engine.
