Muffler Replacement
- Capt Happy
- Vessel Info: 1974 16 Foot ex DFO Lapstrake Speedboat
1985 21 Foot Baby Cape Islander
1977 26 Foot Trojan F-26 Cruiser
1997 Carver 320 Voyager - Has thanked: 32 times
- Been thanked: 16 times
Muffler Replacement
Reaching out to the community for help in sourcing a st'bd side replacement muffler for our 1997 320 Voyager.
The original muffler was manufactured by Naqualift. This is a four inch, two in, one out horizontal setup. Engines are Crusader 350XL's.
Have reached out to Great Lakes Skipper, Marine Parts Source as well as other distributor's. They are unable to cross reference this it seems.
The Carver part number is 5111701. Any help or advice on where to head next would be greatly appreciated.
Thanks in advance for all replies.
cheers, Capt Happy
- paulr
- Vessel Info: 396 CY Aft Cabin 2001 8.1 Crusaders
- Has thanked: 52 times
- Been thanked: 31 times
Re: Muffler Replacement
A new muffler of course was not availible.
- Been thanked: 1781 times
https://centekmarine.com/markets/recreational/
What's wrong with the existing one? What makes you think it needs to be replaced besides the way it sounds per your other post?
- Capt Happy
There is no apparent damage visible from the outside. The reason we are considering replacing, is due to the very noticeable increased exhaust noise from this side compared to the other. Do you have any experience with the slip in silencers ?
A silencer may quiet things down but you have to wonder if that's just a band-aid fix, if indeed there's a physical problem. Anything you introduce into the exhaust system will contribute to back pressure and can affect engine performance so be sure you're not minimizing one problem but creating another. Is the noise intolerable or is it just annoying you because you know there's a difference? Does anybody else bring it up?
- Has thanked: 602 times
- Been thanked: 1302 times
Perhaps removing the muffler and inspecting it thoroughly on the inside including hoses etc whilst apart.Root cause is very important to this.
I had a boat that had the exhaust system hung from the above decking but over the years the hangars became broken and had been fooled with by improperly fixing them with strapping. Once I fixed it back to flexible service again ( much like a car exhaust hangar) the noise and vibration subsided considerably. Now this might not be your case but just an illustration.
- Capt Happy
I have experimented with shutting one engine and then the other down while comparing them both, away from the dock, on open water and without any outside factors, i:e wind, waves, vessel list. Everything being the same, it is quite a noticeable difference. That being said, while side to at a dock, this becomes even more apparent.
I prefer not to have to purchase a new muffler, so will disassemble and look at the internals. Although if the baffles have failed, not sure if this could be repaired?
The main reason for the post was, the current producers, Centek, Corso, etc are unable to provide a recommended replacement.
I am able to find vertical lift exhaust components from Naqualift, but nothing horizontal. So I was hoping maybe someone had replaced theirs over time and had a source for a new one, if required.
Check with these salvagers in Florida...
https://www.themarineconnection.net/
https://donsmarinesalvageyard.com/
Users browsing this forum: No registered users and 117 guests
