Carver 3607 electric galley help
- JJ312
I'm redoing the electrical system on my Carver 3607, and frankly, it's a mess. I need to change the chargers, and I'm not sure how to redo the distribution panels without tearing everything out. It’s honestly more complicated than optimizing the latency in an online game at least there, if you mess up your settings, you don't risk a fire! Has anyone here done this before? Any tips and tricks to avoid burning the boat or breaking the bank on reliable equipment?
Thanks, guys.
- Been thanked: 1789 times
Re: Carver 3607 electric galley help
buss bars, etc. It also helps to take enough pics that will help in reassembly later.
Why do you need to replace the panel?
- Been thanked: 489 times
- Been thanked: 1109 times
I had a 3607 and did major rewiring under both helms, but I thought the main panelboard (breaker panel) was pretty well done from the factory. I added fuse panels to replace the junction blocks under each helm so the wiring was much cleaner and also provided separate fusing for different functions, rather than it all be just protected by the main "helm" breakers.
Do you have the original wiring diagrams for the boat? Depending on what year yours is, I might have info to help. I have the original docs for a 83 model and could email to you.
Users browsing this forum: No registered users and 67 guests
