For 350 mariner owners, battery charger location
Topic author United Arab Emirates
dlldxb
Vessel Info: 1999 350 Mariner
Been thanked: 3 times
Postby dlldxb » April 29th, 2026, 10:44 pm
The Charles charger on my 1999 350 mariner is due for replacement. Issue is the location. Only access is via the storage box on port side dinette I will replace with victron phoenix smart charger 50a/3
I have enclosed my renders of possible solution and welcome feedback on What others have done
Re: For 350 mariner owners, battery charger location
Postby bud37 » April 30th, 2026, 11:42 am
Something that I considered when we replaced ours in the same model.
They have remote displays and controls for some of these units now so getting an eye on them may not be a regular need IMO. In reality once you get the charger working and trust it, ya really forget about it.
The only thought may be to try and keep the engine compartment air separated from the salon space air, that tub kinda sealed that hole under the seat cushion. Now I realize this may be next to impossible but can be kept to a minimum with some thought.
dlldxb
Postby dlldxb » April 30th, 2026, 8:51 pm
How hard was getting access to wire the new one? My drop in storage bin didn’t seem to be sealed but the panel they installed ahead of engine bay did
dlldxb
Postby dlldxb » May 1st, 2026, 6:59 am
UPDATE UPDATE - On review again, decided against the portal and will just install the Victron. However, I was informed that ventilation should be installed. Even though this is the factory install, a friend of mine who works for a boat builder was surprised to see no ventilation fan in the dinette set; he recommends putting one. Anyone have this as an issue? The Victron has heat sync and I don't expect too high temps.
Postby Viper » May 1st, 2026, 5:44 pm
There's probably more air movement in there than you think. Isn't it open to the bilge? Of coarse a couple of vents in close proximity would help but I don't think you need a fan. It's all a moot point though if you shove a bunch of stuff in there for storage and limit circulation.
dlldxb
Postby dlldxb » May 1st, 2026, 9:35 pm
It’s sealed to the bilge and there’s a large plastic storage bin that drops in place
Postby bud37 » May 1st, 2026, 10:03 pm
dlldxb wrote:Source of the post It’s sealed to the bilge and there’s a large plastic storage bin that drops in place
That entire side is open up forward under the galley, center bilge, to below the bridge etc.....just look under the forward storage bin next to the galley...you can climb in there if no extra AC unit....lots of air movement imo. Check it out to see.
The old ferro charger would have got hot.
